Need your Advice/Help
I have a highschool prom to go to and I would like to be able to let out a rather large sized, head turning smoke cloud
. this would only be a one night thing(fuel prices
) so I would need to be able to put the pump back to my stock position. What do you guys think would be my best move without spending any money?
Thanks!
Wheelo
) so I would need to be able to put the pump back to my stock position. What do you guys think would be my best move without spending any money?Thanks!
Wheelo
Smoke screw all the way down, starwheel down, fuel pin turned or grind, full P screw as far as possible w/out runaway, and take off a turbo boot clamp
LOL! J/K about the clamp, although it would allow for a heck of a cloud.
ha ha, always got to show off for the ladys hey, the best way is to pull the pump top off and remove the afc lever proporly so you can put it back on, and if you have the stock turbo it should blow some good smoke, with the fuel screw in max, expesialy when your doing a burn out of pulling hard out of the parking lot all they will see is black, hahaahaaahaaaahaaaaaaaaaa
Make sure you check for free throttle lever motion when you put the TPS back on, if you don't get it lined up right it can make the throttle hang up.
you can allways put a tobe of grease down each stack we did that do a buddys powerstroke at a party one time while he was past out but it contiuse to smoke after u turn it of but he sed it never cout on fier its up to u i wuldent but its a sugjeston
