Need pic of combination valve location!
Title says it all really.
Now, here's the explanation if you're interested.
When I bought my truck, I knew it had it's share of problems....blah blah blah. I found out recently that someone, somewhere yanked the combination valve, and replaced it for a proportioning valve and residual valve set up. So now I'm obviously going back to the C/V set up to hopefully eliminate my sinking brake pedal affliction.
If you gotta pic of the C/V handy I'd appreciate it. I can't find any holes in the frame rail that match up to the mounting holes in my C/V, so I'm assuming it has a mounting bracket as well?
Thanks all!
Murf
Thanks all!
Murf
Thanks all!
Murf
Thanks all!
Murf
Mine's an auto, not sure if that'll make a difference or not. The FSM assumes you're replacing a factory part, so it doesn't go into exact placement. and it doesn't differentiate between auto and manual.
Don't kill yourself with the pic, but the help is appreciated!
Thanks again
Murf
Pumperdude2
Jun 12, 2015 01:08 PM
woodcutter1983
Jun 17, 2012 06:44 PM
