another Glow Shift question
Old Oct 18, 2010 | 08:06 AM
artieb's Avatar
I see that Glow Shift has a 3 in 1 gage, boost sweep, EGT, and a temp. I thinking would use the temp for the engine oil temp, on my 5-sp truck. What I don't know if I can use my headlight switch for the dimmer, or even if I can dim the "backlight"? I'm waiting for G. Shift's tech support, too. What do you guys think? Thanks, Artie
Old Oct 18, 2010 | 05:16 PM
dieselJon's Avatar
The dimmer wire dims the gauge about 25% less than when the lights are off. So no, you cannot use the dimmer switch to "dim", just when that wire gets power will it dim.
Old Oct 18, 2010 | 05:35 PM
Dean Snow's Avatar
Ive seen two of my buddies try them gauges and they had no luck. Both theirs came in the same box to the same house and neither of them worked correctly. Could just be a fluke though.
Old Oct 18, 2010 | 08:05 PM
DNRCustoms's Avatar
I just installed one and didn't really care to much for it. Didn't like how you couldn't dim it using dimmer wire. Also, button stuck on me. Maybe, just my experience. But I like the old school guages!!
Old Oct 18, 2010 | 08:22 PM
i like glowshift just put one in a guy's 90 cummins and the egt gauge worked good.
Old Oct 18, 2010 | 08:29 PM
Onemoparnut's Avatar
I put a glow shift fp gauge in a friends truck and the sender went bad in a week. They were easy to deal with to get it replaced and it is working good now.
Old Oct 18, 2010 | 10:37 PM
B-North's Avatar
I have the 3in1. Works fine I would rather have 3 separate gauges but the price on the GS was much more reasonable. Biggest complaint is reading the digital section is difficult in daylight because of the tinted face.
Big Red 97'
Aug 17, 2009 05:43 AM
SmokemS
Feb 24, 2008 10:05 PM
rustybudweiser
Jan 28, 2008 01:50 PM
oldblues
Dec 17, 2007 09:30 AM
dieselfuelonly
Oct 17, 2007 09:26 AM
