need more fuel
need more fuel
how much h.p. do you think i could get from a 93 if i put lucas pod's and turned up the pump all the way? what else could i do to get more fuel through the injectors? delivery valves? governor springs? i want AT LEAST 350 hp.& 800 ft lbs. i alredy have a 12 cm turbo housing.
AFC pin that sit under the cap on top of the VE pumps, hooked to a diaphram thats spring loaded and as manifold pressure increases it pushes down and allows the pump to push more fuel. Mine's a custom one and looks like this. Very close to an Old Smokey pin.
Skidoo01
Jan 29, 2010 10:22 PM
Commatoze
Nov 20, 2003 06:06 PM
