Need help installing POD Injectors!
I'm getting ready to install a set of Prince Of Darkness Injectors in a '93 CTD. I've been told to use the .020 washers but the installation kit doesn't even have them in it. Will the .060 washers work OK? Where can I find the .020 washers?
And where could I find a good deal on the 3200 gov spring and a fuel pin?
Thanks!
-Ben
Thanks!
-Ben
If you're looking for the cheapest, there is a company on ebay that sells the bullydog fuel pins, I believe. I remember they were cheaper than the genuine old smoky pin that I got from DDP. Or you can grind your own.
Your local pump shop can get you the 3200 spring. I know that piers can also get it for you.
Ben,
The .020 washers will position the injectors with a better relationship to the piston. Call the vendor you ordered your's from or any of the dealers that sell them.
Aloha,
Aloha,
A pump shop will be able to supply you with the washers. You might have to buy a whole install kit to get them, but you can find them. Ask for a Cummins B&C injector install kit.
BrokeSolid
21
02-03-2009 09:36 AM
SilverRam3500
02-17-2008 03:10 PM
sledneck1
13
01-29-2008 12:38 AM
Micaiahfied
03-10-2007 06:01 AM
