need help!!!!!
Old Aug 13, 2009 | 01:47 PM
1bad93's Avatar
need help!!!!!
ok whet to get some drinks today and right befor i shut the truck down i looked at my dash and the check engine lights on and the voltage meters going crazy what is this? im thinking the altanator but im unsure????????
Old Aug 13, 2009 | 02:35 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
Check the codes to see what the light came on for.
https://www.dieseltruckresource.com/...58#post1107258
Old Aug 13, 2009 | 03:18 PM
1bad93's Avatar
ok ill try that then
Old Aug 13, 2009 | 03:34 PM
Pod Boy (on hiatus)
My buddies truck did something similar, volt meter was going crazy, and check engine light indicated charge system low voltage. Turned out the main charge wire had come loose from the alternator. It would have taken a long time to figure out if we had not checked the code.
Old Aug 13, 2009 | 04:59 PM
1bad93's Avatar
well i went and took a peak under the hood found a lose ground and that solved it, thanks for help everyone.
Old Aug 13, 2009 | 05:04 PM
peobryant's Avatar
Don't thank everyone, we didn't do anything. Thank the "Pod Boy."
Old Aug 13, 2009 | 05:05 PM
1bad93's Avatar
well you got a point, but you get what i meant.
Old Aug 13, 2009 | 06:06 PM
Pod Boy (on hiatus)
No problem, happy to help. I totally forgot about the "pod boy" thing till you said that. Figured it Dave would have change it back by now
Old Aug 13, 2009 | 07:32 PM
Aren't you still the pod boy?
Old Aug 13, 2009 | 09:36 PM
Pod Boy (on hiatus)
I suppose I am still the pod boy. Too hot right now to do fiberglassing, but this fall, I will be pod boy again.
Old Aug 13, 2009 | 09:49 PM
peobryant's Avatar
Eventually, I'll get the pod you made me installed. Sorry I haven't been able to do it yet, been real busy. It's nice to look at though.
Old Aug 14, 2009 | 03:00 AM
Pod Boy (on hiatus)
I have had some interest, but I am afraid to make more till i KNOW they fit good. The others I made have not given me much feeback either......Plus its too hot to make more right now..... You have till fall to get it installed
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
