Need Help
Old Jun 20, 2008 | 07:49 PM
Originally Posted by ontario country
VSS is working fine, actually a new one was installed by trannie shop. Speedo and overdrive work fine when check engine light is on, and also works immediately with the PCM from the gas job with the exception that the speedo is very erratic with the gas PCM in there. Why would I only have 4 volts with right PCM and 8 volts with the one from the gas job? Thanks for all your efforts
I forgot about that whole crazy mess. Sorry 'bout that.
Was wondering if there is any possibility that it could be the ignition switch, since if you are driving and throw truck in nuetral and shut switch off and then turn it back on without starting the truck, the speedo works. How hard is it to change the ignition switch? Thanks again.
Yes, I would throw an ignition switch at it. They are pretty cheap if you get an aftermarket one. It's not hard to change, but you do need a security torx bit (T-15 I think) for the screws. All that has to come off is the column cladding (3 screws from the bottom) and you are looking at the switch.
Old Jun 25, 2008 | 08:28 PM
ontario country's Avatar
I am waiting for an new ignition switch to arrive $18. plus tax from the dealer. will let you know teh outcome. Thanks
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
