My 1990 W250 Build
Nice project. And I can definitely understand you frustration with "other guys work"!! I have pretty high standards...so I don't trust others to do work on my vehicles.
Heck why pay someone a lot of money to $crew things up...I can $crew things up myself for a lot less....
This is how I got my box....traveled 6 hours..one way to go pick it up.
Made up some bed stakes...then strapped it down.
Got the lift pump, IP, and tappet cover gaskets today along with the tappet cover seals. Plan to replace them as soon as the weather breaks. I've been leaking but it seems that it's gotten worse (1 qt every 100 miles)
New front rotors, brakes, seals, and a tub of bearing grease, just need to order King Pins so the front steering is complete. Also just ordered some Blue Super Bright LEDs for the instrument cluster. Will be nice being able to read the left side gauges once again.
I did find enough iron and hole saws for my front spring hangers though
So the lifter/tappet cover gasket leak I thought I had turned out to be nothing more than a combination of the last two valve covers and the lift pump gasket. Made quick work of that today and the oil leaks are gone. Best part is I can put $40 back in my pocket.
With that said I'll never buy a gasket for this truck that isn't a Cummins brand gasket again. The lift pump gasket I got with the lift pump is substandard quality compared to OEM Cummins brand.
Next on the list is getting the new bed out on and the second gas door welded in.
I don't have any progress pictures, but I have made some progress this week. I ordered a new head unit, amp, and speakers to replace the "brand new" 10 year old alpine unit (I miss having my iPod for tunes). I got most of the LE molding off the truck cab today, ordered new front side marker lights from rock auto (broke the plastic tabs when removing nuts), and cleaned up the fender flares prepping them for 2 sided tape. Want to have them installed before the rockers/flares get a treatment of line-x. I do have a few trim holes I need to weld up before I get that done though.
I am having a hard time deciding if I should line-x over the flares making them part of the fender or line-x the flares separately and install the line-x'd flares over top of the line-x'd wheel wells. Thoughts???
I always paint parts separately if possible. I looks much neater like thought went into it. I am pretty critical( That's what my wife says)
When everything is painted(together) there are always spots that you will miss. And to me looks like a Hack job.
at least it is easy to go back.
