multiple VSS failures
Old Dec 31, 2008 | 09:27 AM
JWood's Avatar
I've lost 3 Vehicle Speed Sensors in about 6 weeks.
I do have a small fuel leak that started just before this happened, coating the undercarriage with gunk. its been too cold to fix the problem, but I guess I have to bite the bullet.
has anyone else had VSS failures like this after a fuel leak?
Ive been using the Napa replacement, is there a better one, is there a cheaper one?
thanks in advance...
Justin
Old Dec 31, 2008 | 02:43 PM
92roughstock's Avatar
My personal experience (and the experience of the busy shop my girlfriend works at as a service writer) has been that parts stores sell junk electrical/ electronic anything, with a few rare, and far between, exceptions. I had 3 O'Reilley's VSSs go out in a year. Replaced under warranty, but still a hassle. I bought a Dodge one, and had no problems for the next year that I owned the truck.
Get out your multimeter, and jump a wire from the positive terminal to each wire going to the VSS. Mom's truck had a broken wire, and it would intermittently give a sero reading. Replaced the section of wire, and all has been well.
Also check all body and engine grounds. Grind paint off, seal with silicone, etc, etc.
Old Dec 31, 2008 | 03:01 PM
JWood's Avatar
i spliced in the new connector that NAPA sends in the box and it worked great. my question is arent these sensors sealed? why would it care if fuel / oil got all over it?
I think I found all the leaks, so Ill try yet another sensor and see what happens... sucks not having OD.
Old Dec 31, 2008 | 03:35 PM
pwrtripls1's Avatar
I bought a new gear, housing, and speed reducer from the dealer and a Napa speed sensor last year and no problems other than the plug, which I cut off and did an enviro splice. No probs since.
rip 112
19
Jun 17, 2008 09:38 AM
Wulfdiesel
16
Sep 15, 2007 12:37 AM
2002CumminsRam
May 21, 2004 04:39 PM
dakar
Feb 20, 2004 08:16 PM
AaronT
Jan 29, 2004 08:15 PM
