MPH and boost numbers???
Old May 27, 2008 | 05:39 PM
dodgethis91cmns's Avatar
today on my way to work i was really seeing how good my new lift pump was working (still need the fuel pressure gauge) but it seemed to be working good. i was noticing that cruising at about 45 mph i was holding at 2psi of boost. at around 50 mph i was around 1 1/2 lbs of boost. it seemed low to me but i wasnt sure, what do yall think????
sorry for the dumb questions i dont know any better
Old May 27, 2008 | 06:08 PM
archer39's Avatar
that is lower than what i see but maybe my truck is not normal. around 55 i normally see about 5-10 psi. not much flat land around me so i am normally going up some type of hill
Old May 27, 2008 | 06:24 PM
Dean Snow's Avatar
i see around 2 lbs of boost at 75+mph crusing.
Old May 27, 2008 | 07:03 PM
yea all my numbers came from flat land driving if it helps at all
Old May 27, 2008 | 09:23 PM
Rampage1967's Avatar
Mine runs 4 - 6 psi with a 14mm wastegated housing @ 75mph.
Climbs fast with throttle application at anything above 45 mph tho.
Old May 27, 2008 | 10:32 PM
MoparMarv's Avatar
Flat land and 60-80mph for me is around 2-5psi. Your #'s sound about right. Try changing the aircleaner. I noticed more boost after I put a fresh stock one in. I have been noticing my boost seems low so i may try it again since I have one on the shelf.
Old May 28, 2008 | 05:31 PM
It sounds normal for a truck with a big housing.
Old May 28, 2008 | 09:22 PM
Alwaysworking's Avatar
alwaysonDTR
about 8 psi at 65@2-2,100 rpm with 500* post turbo.
treemonkey
Jun 17, 2009 02:06 AM
sCreamin400
Nov 2, 2008 01:46 PM
pred
Feb 12, 2007 12:22 PM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
