More Problems
Got the contacts changed, now there is not power to anything the key has to be on for it to work. The wiring is from hades so im taking it to an electrican tomorrow. to get it worked on. What might be the problem?
Could be the bulkhead connector? I`ve had them give me probs on other Dodge trucks I`ve had. It`s on the firewall near the master cyl, it`s held together by a 8mm(5/16) bolt in the center. Pop it apart and look for green crud on the contacts.
If you had power to everything before you "fixed" it, and only changed the starter contacts, I would suggest that you start right there and take it back apart and reclean things and put it back together. Many times I have run into that same scenario and found one wire end has just enough corrosion left on it to break contact, causing one circut to not power up. Sometimes a wire drops down and you miss it when reassembeling it. Good luck
Took it to an auto electric guy (who is a god in my books) a couple of wires are bad and the cable is bad so he is gonna change them and then fix a couple of lights and ill be in business. thanx for your input tho guys i looked and looked and couldnt find it tho. so i took it to a professional.
JyRO
Jan 20, 2006 09:28 AM
Commatoze
Nov 20, 2003 06:06 PM
