Modifying An 8 ft. Bed
Old May 24, 2010 | 03:41 PM
AUGIE DOG's Avatar
I need some suggestions on how you would shorten an 8 ft. bed and make it a 6 ft. bed. Is it possible, and has anyone ever done it and what challenge's will I run into? I have an 85 crew cab with a short bed and want to make it a dually short bed. I have a bed lined up complete with fenders and that is what I am modifying to fit my truck. The possibility of lengthening the frame is out of the question because that will defeat the purpose of what I am attempting to do here. Thanks for your help!
Old May 24, 2010 | 03:51 PM
Mieser's Avatar
If the 6ft bed is decent, why not install the dually fenders on it? I would think this would be a lot easier than front-bobbing the 8-foot bed.
Old May 24, 2010 | 04:31 PM
Onemoparnut's Avatar
The long bed would need to be bobbed some between the cab and the axle. Then again between the axle and the tail lights. All of the extra legnth is not in one place. Would be easies to adapt the dually flares to the short box like mieser said. (if you have a short box)
Old May 24, 2010 | 09:19 PM
AUGIE DOG's Avatar
The problem with the current 6 ft. bed is the wheel well opening.I have a driver side dually fender and held it up to the bed and the fender diameter is much larger than the current opening. My bed has rust around the top of the wheel wells and I do not have a problem with grafting the larger dually wheel well in it's place. I will also need to rework the inside of the box. This is the reason I am asking what would be easier...shorten the bed or graft dually wheel wells onto existing bed. Keep the ideas coming!
Thanks!!
Old May 24, 2010 | 09:26 PM
PapeCAT's Avatar
there are aftermarket dually conversion fenders you can use on that 6ft bed made by arrowcraft I believe.
Old May 25, 2010 | 12:26 AM
Trooperthorn's Avatar
In my opinion, it would be easier to radius out the short bed fenders to fit the dually flares. If that removed all existing rust, problem solved.
As far as shortenning the dually long bed, the big issue is rewelding the bed skin back together after taking six inched out of the rear and 12 inches out of the front. Welding up long seams on exposed surfaces is a craft. So many people just get it close then slathe a galloon of body filler on it and call it good.
I like the dually shortbed idea. I was going that direction but changed my mind and sold my rear flares. Pics when done?
Old May 25, 2010 | 04:22 PM
AUGIE DOG's Avatar
Thanks every one, your suggestions is what I was looking for. Papecat I am aware of the Arrowcraft fenders. I toyed with that idea but....they look like DARE I say it "chevy" fenders!!!! I can't have that!! lololol!! Trooperthorn I was considering doing radius to the wheel well and that would take care of the rust. Would you need to enlarge the inner bed wheel wheel wells also? Now another thought! Cut down (reduce) the width of the rear axle so the outer wheels will be under the bed more and I could get by with a wide 4wd fender flare. I don't know the cost of this but I have seen a couple of trucks in my area that have done this. Just a thought... Yes I will do pictures when I get started.
Thanks Evey one
Augie Dog
Old May 25, 2010 | 10:19 PM
I don't think the inner fenders are different on the duallies. It is just the outside that needs to be hacked. There are bolt on fenders that look exactly like the factory. I don't know where you find them, but alwaysworking got his with a bed at a wrecking yard.
Old May 25, 2010 | 10:28 PM
PapeCAT's Avatar
Arrowcraft looks stock to me
http://www.arrowcraft.com/products.php#fenders
Old May 25, 2010 | 10:38 PM
Originally Posted by PapeCAT
Yep. Thoese are probably them.
Old May 26, 2010 | 04:21 AM
AUGIE DOG's Avatar
Papecat,please accept my apology! It seem Arrowcraft has come a long way with their products.When I first researched them (5 yrs. ago) all they had was a chevy/ford looking fender and did not offer a dodge. Thank you for bringing this to my attention.
Old May 26, 2010 | 04:32 AM
KD93's Avatar
I was wondering what you meant Augie Dog. I had a look yesterday and they looked pretty darn close to me! I need a set and these may be the way to go... I just don't know how they attach. I know how the factory ones go on, but the picture on their website doesn't show a lip on the 'bed' side to bolt it up.
Old May 26, 2010 | 04:15 PM
AUGIE DOG's Avatar
OK! I believe I may have solved my dilemma. I e-mailed Arrowcraft and their reply stated the dually fenders they sell "WILL NOT REPLACE STOCK/ORIGINAL DUALLY FENDERS" they are not exact replica's of original fenders. Stock fenders are mounted inside the wheel well hence the reason an original dually beds wheel wells are larger than a single axle wheel well. The fenders they sell mount to the outside of the well onto the quarter panel of the box and all parts are included in the selling price of $495.00 tax not included. I am calling them tomorrow to ask more questions and I will get back with every one on this thread. Thanks again for all of your input and to Papecat for suggesting Arrowcraft. Like I stated before they did not offer these fenders when I originally purchased my truck so I did not research their company.
Thanks!
Augie Dog
Begle1
Apr 19, 2004 07:24 PM
shaft
15
Apr 12, 2004 04:46 PM
chucktownsend5
Nov 21, 2003 11:08 PM
Commatoze
23
Dec 2, 2002 12:02 PM
