In the middle of my KDP
Old Oct 16, 2011 | 12:31 PM
Mopar1973's Avatar
KDP itself is taken care of, but now i'm a little stuck on the location of the timing case bolts, can anyone help me out? Also what color loctite should i use? Thanks!
Old Oct 16, 2011 | 12:49 PM
torquefan's Avatar
There are 5 internal case bolts. 1 is beside the KDP. One is down low on the passenger side, close to the oil pump, and 3 are behind the cam gear (one of which is really hard to get a wrench on, and impossible to remove.)
Blue loctite should be fine. (medium strength).
Old Oct 16, 2011 | 01:04 PM
Mopar1973's Avatar
are the ones near the cam gear in almost a square in terms of location? I thought it might be them, but didn't want to take them out until i was sure.
Old Oct 16, 2011 | 01:10 PM
Mopar1973's Avatar
and what is the torque spec for them?
Old Oct 17, 2011 | 11:44 AM
torquefan's Avatar
I think they all kinda curve down around the right side of the cam gear (when viewing it from the front.) The torque spec is 18 ft/lb and they will all take a 10mm wrench. Don't confuse them with the cam retainer plate that takes a 13mm wrench on its two bolts.
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
TIMMY22
Mar 22, 2009 08:39 PM
TIMMY22
Dec 24, 2005 10:06 PM
