Me and Jeff made a couple hooks tonite.
Had our last fairly local pull last night.
Me and Jeff did pretty decent In the 8000lb 2.6 class I went 394' 11" and ended up 6th and Jeff went 405'3" and was 5th, For grins and giggles we also pulled in the 2.8 class and I went 412'6" and ended up 4th and Jeff went 414'5" and was 3rd
I now have a coolant leak that I need to track down i think its just dripping out of the weep hole in the pump but I'm not sure.
Video will be up tomorow.
That was the first time I powered out and got under the charger in a long time, I don't know if having the water temp guage pegged had anything to do with it. The water pump also started leaking out the weep hole so now its got a new reman on it.
And after a close inspection of everything the only carnage was a leaky pump, and I also popped one of the spots where I soldered the rad. I also destroyed another set of motor mounts.
CaptainChrysler
Aug 12, 2011 11:45 AM
24seven
17
Jul 5, 2007 01:21 PM
