Man we're having a good time! (Coolant Leak)
Old Mar 3, 2014 | 11:36 AM
Subliminal's Avatar
So, my truck started dripping some coolant at the beginning of the winter. Nothing big, just a drip.
Well, of course times they change and that drip is now a serious issue.
At first, I thought it was the hose clamps...tightened them, no such luck.
Then I realized I never took the heat exchanger off the side of the block when i did the transmission swap, and that it had lines going to it and it looked like they were wet.
Removed that ditty, but to no avail.
So, I dried everything with air, filled it back up and let it sit. Drip drippin' away. Looked like it was coming from one of the two water pump bolts. So, I removed the water pump (which is ridiculously easy on this thing) and resealed it with RTV. Put it back together figuring surely I fixed it.
Drove it to get it to operating temp, parked it. Looked at it an hour later...no drip. Looked 2 hours later...dry.
Went out this morning and there must be 2 quarts on the driveway.
DOH! I know it's coming from the front of the engine (ish...ha), but i cannot find the friggin leak.
Like a pirate wheel in the pocket, this be drivin me nuts!
Old Mar 3, 2014 | 11:48 AM
jimbo486's Avatar
Check the water inlet on the side of the block above the AC compressor. There is a flat o-ring seal between the AC compressor mounting bracket and the block.
Old Mar 3, 2014 | 11:49 AM
Subliminal's Avatar
Will do, thanks Jimbo.
Old Mar 3, 2014 | 03:57 PM
mknittle's Avatar
Mine leaked out of the hole in the water pump. the fan blew it all over the front of the engine. Made it a PITA to find.
Old Mar 3, 2014 | 04:11 PM
Dieselbuilder's Avatar
Check the front of the head maybe a head gasket?
Old Mar 3, 2014 | 08:52 PM
sooty's Avatar
jimbos probably got the right one, the temps their experiencing are insane in ny, (for us California boys) cold shrinks metal to leak, and that gasket has been the culprit many times, they get a rotten look, youll see evidence if its leaking
Old Mar 3, 2014 | 09:01 PM
Subliminal's Avatar
If a guy were going to get one of those gaskets, to have on hand should that be the culprit... What would he call it.
Ha. Anyone had to purchase one before? Something I can get at a parts store?
Sent from my XT1049 using Tapatalk
Old Mar 3, 2014 | 09:51 PM
jimbo486's Avatar
A Cummins or a Cummins parts distributor can get you one. I don't have a part number for it at the moment but I can probably find one for you.
Hunted and pecked from a Galaxy S4A.
Old Mar 4, 2014 | 07:01 AM
Subliminal's Avatar
That would be awesome, thanks!
I've been looking online for parts catalogs, but I don't think they apply because they are all for generators or the like. ;-)
Old Mar 4, 2014 | 07:11 AM
jimbo486's Avatar
Water inlet connection seal/gasket P/N 3906697. $1.56 when I bought one last.
Old Mar 4, 2014 | 08:18 AM
sooty's Avatar
yeah that..............I get that at local parts suppliers, napa oreillys I also silicone them down
Old Mar 4, 2014 | 08:22 AM
Subliminal's Avatar
You know...I actually had a leak there a while back and used RTV to seal it, so I don't think that that is my leak, unfortunately.
I'm going to replace the water pump. That lil hole is what i assume the problem is, but I guess we'll see. I thought for sure it was the bolt below it. Ha.
Thanks guys, help is much appreciated!
Old Mar 4, 2014 | 08:34 AM
Rick 12v CTD's Avatar
I had a leak a few years ago at the water pump. Turned out to be the o-ring that seals it. I just replaced the whole water pump. Truck had over 250k miles on it anyway so I figured it was time. Pump came with a new o-ring. Problem solved.
Not saying it isn't, but I've personally never seen that hole leak before.
Sent from my SGH-I747M using Tapatalk
Old Mar 4, 2014 | 08:38 AM
Subliminal's Avatar
Roger, Dodger...thanks for the reply!
Old Mar 4, 2014 | 08:45 AM
maybe368's Avatar
That hole is put there by the factory so that, when it leaks, you know that the pump is failing. They call it a weep hole...Mark
