LP-Piston pump upgrade, not so good
Just installed my LP piston pump today since i was seeing 0psi with the diaphragm frequently. Fired it up and had 9-10psi, drove it around and it doesn't get under 5psi. Cool i thought. Went on a 2hr road trip and am seeing 0 at times and up to 8psi other times, strange.
I am going to verify my pressure sensor isn't shot, anything else that could be causing a low pressure? Fuel filter may have 1000km on it.
DAP sells the wrong one. It's not an equivalent to the 3936320 low pressure Cummins pump. It's really no better than a stock replacement diaphragm pump. Also 9-10psi is normal for their pump. 12-18psi is normal for 3936320.
That is good to know. I was getting ready to buy on of those kits but didn't like the fact that there was no info who who makes the pump. I'll just get the correct one form cummins.
cummins pump
I have the cummins low pressure lift pump it runs between 12-20psi good upgrade. It's not an equivalent to the 3936320 low pressure Cummins pump. 12-18psi is normal for 3936320. This is by far the best up grade I've made to my 92 dodge cummins. I also was going to order this kit dap sells.
I'm thinking u may have a fuel restriction my only guess.
john
john
How does having greater fuel pressure benefit the IP ?
EDIT:
Never mind. It prevents fuel starvation with larger injectors....
Good OLD thread for part #'s, BTW.....
https://www.dieseltruckresource.com/...mp-t84412.html
EDIT:
May have found one here, will see when it arrives.
http://www.cumminspartsdirect.com/Ca...ift-pumps.aspx
