LP lift pump spring
Old Dec 23, 2010 | 02:12 AM
Crazy Matt's Avatar
LP lift pump spring
Anyone come up with a spring yet?
Im thinking about experimenting - http://www.mcmaster.com/#compression...prings/=a9oaze
Id like to have a spring to go from tho and fine tune it from there
https://www.dieseltruckresource.com/...ft+pump+spring
Old Dec 23, 2010 | 08:57 AM
deanhinsley1963's Avatar
Why not just go with a 2nd gen. lift pump and regulater and adjust it from there?
Old Dec 23, 2010 | 09:16 AM
apwatson50's Avatar
I had thought about finding a spring to put in the 2nd gen pump to get 15psi. This way you don't need an extra item, regulator, to mess with or go bad.
I think you will want a spring with a spring rate of about 25 lbs/in.
I put a 2nd gen spring in my press on a scale and it took ~60lbs to compress an inch. And i'm told that a 2nd gen pump will make 45psi if it is dead headed.
This is from memory earlier this year, so the information contained may or may not be completely accurate.
Txwelder
Nov 26, 2025 01:53 AM
WhoCares79
Jun 3, 2008 11:45 AM
flynhigh205
Feb 26, 2008 10:33 AM
fishin fever
Mar 13, 2006 06:46 PM
Txwelder
May 19, 2005 06:10 PM
