Low, lopey idle when hot?
Old Jul 7, 2011 | 05:14 PM
mhuppertz's Avatar
With my A/C on and hot as it has been, my idle gets low and lopey. Not sure what is causing it....
Old Jul 7, 2011 | 05:22 PM
Richie O's Avatar
366 Spring Chicken
You murdered your ip when your lift pump plugged.
Old Jul 7, 2011 | 05:24 PM
mhuppertz's Avatar
Maybe, but it was doing it last year before I plugged the pump. I think Jet A might be making it worse.
Old Jul 7, 2011 | 05:59 PM
jeepsuck's Avatar
How did you plug the lift pump?
Old Jul 7, 2011 | 06:04 PM
mhuppertz's Avatar
The screen at the bottom of my pickup assy in the tank was torn and I didn't know it.
Old Jul 7, 2011 | 06:37 PM
maybe368's Avatar
Mark, are you putting lubricant into the jet-a? I don't know if it matters or not, but the thought crossed my mind...Mark
Old Jul 7, 2011 | 06:38 PM
mhuppertz's Avatar
Good thought, but yes I am.
Old Jul 7, 2011 | 06:42 PM
maybe368's Avatar
Cool, other than that I am fresh out of ideas. My 90 has a high idle **** that I use sometimes with the ac on, but, I think I read on here somewhere that only 89's and 90's had them. Mark
Old Jul 7, 2011 | 06:48 PM
ChrisLib's Avatar
worn/tired pump, been there myself.
Old Jul 7, 2011 | 07:17 PM
CaptainChrysler's Avatar
The jet fuel is thinner right? (lower viscosity) If so, it will leak past the H&R more than #2.
I would say the H&R is tired, jet-a is amplifying the problem. Mix some oil in with it.
Old Jul 7, 2011 | 09:40 PM
I was having the same problem.... hence this other thread I started:
https://www.dieseltruckresource.com/...d.php?t=291363
Faith explained the problem in the thread in her last post
https://www.dieseltruckresource.com/...08&postcount=8
Apparently it's a common problem (during hot weather) and can't be fixed without disassembling the pump
T.
T.
taken5875
Apr 20, 2008 03:21 PM
Bob Wagner
May 17, 2007 12:30 PM
Patriot
Apr 17, 2006 08:44 PM
silver_goat
Nov 5, 2004 02:50 PM
98rammer
May 25, 2003 09:31 PM
