Low boost?
Old Sep 1, 2014 | 08:06 PM
Ghosthider's Avatar
Low boost?
What should stock boost pressure be for my 92?
It never seems to go above 12-13 lbs even when I stand on it.
The EGT's usually run 800 and go up to 1200 under load.
Old Sep 1, 2014 | 09:48 PM
BILTIT's Avatar
12 was all i could get from my 91.5, pushing 40 now
Old Sep 3, 2014 | 07:01 PM
Ghosthider's Avatar
What would be a better option rebuilding my stock HC1 with a 60mm intake wheel and 16cm housing or getting a different turbo? Right now the rest of the truck is stock, wanted to start messing with the pump though.
Old Sep 3, 2014 | 07:22 PM
BILTIT's Avatar
I wouldnt bother with a 60mm and housing. Probably be easier and almost cheaper to find a he351cw if you can.
Is your truck an auto or standard?
If you fill out your signature it will help us understand what you have.
Old Sep 3, 2014 | 08:15 PM
Ghosthider's Avatar
It's an auto
Old Sep 3, 2014 | 10:18 PM
torquefan's Avatar
I've found that 1st gens were all over the map for stock boost pressure, and if it's only making 12 PSI you should be able to make a big difference with just pump adjustments, and get the pressure up to 19 or more before spending a bunch of money on parts. I think there's pretty good instructions around here in a sticky or wiki or something. Check your throttle linkage travel first to make sure you are achieving WOT at the pump.
Old Sep 4, 2014 | 08:38 AM
j_martin's Avatar
I run the stock turbine, 60 mm compressor, and get about 25 lbs boost. There's considerable lag on spool up, but with an automatic it doesn't matter. On the rare occasion that I need an extreme launch, I power brake it for a couple of seconds, and the launch is ridiculous, and smokey. (mostly tire)
Southtowns27
Jul 2, 2011 08:50 PM
jmlcolorado
May 19, 2010 10:30 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
