can i loctite these screws?
Old Sep 3, 2014 | 07:33 PM
Brian.B's Avatar
hey guys i was wondering if i could loctite the bolts that hold the little plate on the back side of the injection pump across from the ksb and also do these need to be torqued or can i just tighten them up........
Old Sep 3, 2014 | 11:00 PM
I don't loc-tite mine. But if I was to do it, use the blue stuff. And all I ever do is give them a good torque down...no particular value....you should have a good feel for what you can torque them down to.
Old Sep 4, 2014 | 08:04 AM
gyman98's Avatar
I've never loctited those screws although I see your reasoning. Personally I would use green loctite and use the cows method of torque ing down
Old Sep 4, 2014 | 09:02 AM
j_martin's Avatar
I use loctite blue on small screws I might want to remove in the future. Also, on small screws in critical positions, though it seems to be a lot of trouble, I break out the 1/4" torque wrench and use it. If the torque spec isn't in the Bosch book, you can look up torque specs per thread size online.
I've found it pays off to be picky about such things.
Old Sep 4, 2014 | 12:37 PM
Angry Johnny's Avatar
After 39 years of being a flat rate tech I torque only 2 things.
Head bolts and bearing caps.
1985cucv
Mar 17, 2009 09:06 PM
RDM16CTD
25
Nov 24, 2008 07:35 PM
GasganoFJ60
Sep 10, 2008 01:11 PM
IRoss
May 4, 2008 06:23 PM
MarkT
Dec 14, 2007 10:28 AM
