Lost another getrag... Ugh....
Old Jan 30, 2010 | 12:12 AM
82F100SWB's Avatar
Well, the 'ol Dodge bit me again... Top cover bolts came loose on the getrag; yet again, and since I was on a fairly long highway trip, I didn't notice anything wrong...
I'm assuming it puked a fair amount of oil out, and about 3/4's of the way up the first reasonably steep incline of my trip I felt a lurch in the drivetrain, followed by a vibration... Dropped to 4th immediatley, but it was too late, damage is done. The pocket bearing between the input shaft and output shaft failed... The same as what was the final catastrophic failure in the last transmission, but it had many other issues and made bad noises and jumped out of gear for months, and was not the root cause of it's failure. This was pretty much an instant failure...
Now I'm debating what to do... I was going to work on collecting parts and putting a medium duty trans in there, but I don't have anything done on that yet... I'm half tempted to put an auto in there...
Old Jan 30, 2010 | 06:51 AM
sooty's Avatar
trans woes
now is a good opportunity to upgrade to the nv4500, check forums and stickies, i bought a kit from las vegas drivetrain.com with reman trans, bellhousing, using stock clutch, flywheel, slave, mount adapter. with upgraded main shaft, keyway and lock washer, 5th gear problem is defeated, very dependable transmission. advance adapters sells the conversion parts, or you can get used 2nd gen parts to upgrade.
yfz450guy
Aug 29, 2013 10:53 AM
nitis
Apr 17, 2007 02:43 PM
darrenG
Jun 25, 2006 08:40 AM
Jim Lane
Jul 9, 2005 03:58 PM
RED121572
13
Feb 24, 2003 09:47 PM
