loose steering-borgeson shaft?
Old Dec 18, 2007 | 08:46 PM
nelly's Avatar
My truck has alot of steering shaft play, it seems to be mostly at that greasable piece down by the steering box, what is that thing called? Is it the borgeson shaft that I keep reading about? Where is the best place to buy one?(im in Canada) & what do they cost?
thanks
Doug
Old Dec 18, 2007 | 09:55 PM
D1EZEL's Avatar
Yes, the Borgson is what you need.
The difference is amazing.
Found mine on ebay for a bit of a discount.
Not too hard to install, just some simple tools and some time. The hardest part for me was getting the old one off.
Old Dec 18, 2007 | 10:31 PM
nelly's Avatar
thanks, I will buy one & change the steering box o-rings while im at it.
Doug
Old Dec 19, 2007 | 08:44 AM
BearKiller's Avatar
Yours is greasable ??
I never saw one with an Alemite.
The failure-prone original factory piece is called a steering-shaft coupler.
Borgeson is a brand-name for premium aftermarket steering shafts, columns, etc.
Borgeson makes a complete replacement steering-shaft that eliminates the el-cheapo factory coupler, using a genuine universal-joint instead, along with having telescoping/collapsing ability.
If you have a removable rag-joint, a two-U-joint shaft can be had that also eliminates the rag-joint.
Flaming River manufactures a really nice shock-absorbing two-U-joint shaft for those with removable rag-joints.
A removable rag-joint shaft has a roll-pin immediately above the joint.
The non-removable ones have the rag-joint flange forged right on the shaft.
Now, I have a question for the smarter guys.
The son's W-250 has a non-tilt column and a non-removable rag-joint.
The D-350 has tilt-column and a removable rag-joint.
How big a chore would it be to swap columns between these two trucks ??
Better yet, seeing as how we both prefer the look and bullet-proof function of the NON-tilt column, how can we best go about altering his non-removable rag-joint, such that we can utilize Flaming River's shock-absorbing shaft ??
Thanks.
Old Dec 19, 2007 | 10:20 AM
csft's Avatar
summitracing.com has good pricing on these
Old Dec 19, 2007 | 11:46 AM
DodgerDoob's Avatar
Just search ebay for borgeson. I got mine for less than what Borgeson's web site advertises.
gcliburn
Sep 4, 2006 01:54 PM
EricHeindel
Aug 16, 2006 01:24 PM
Dr.Kayak
May 18, 2006 05:32 PM
getblown5.9
May 9, 2006 05:34 PM
Raspy
Oct 31, 2003 01:17 PM
