looking for internal roof repair pictures
Old Jan 11, 2016 | 10:15 AM
samiam4's Avatar
Title says it all,
I am looking to see the construction of the truck roof. It looks like 3 pieces where the sunvisors attach. I am wanting to do some rust prevention to the area, but don't want to drill through the outer skin.
Help!
Michael
Old Jan 11, 2016 | 12:28 PM
bannerd's Avatar
Best thing to do is get a wire wheel and take it to bare metal. See what you're working with. I have a wand that I stick through the visor hole and spray "rust cutter" all over. It's acid and turns rust into a black paintable surface. From there you can hit it with fluid film or use eastwood (Internal Frame Coating w/Spray Nozzle | Eastwood) then hit with fluid film.
Remove the entire windshield and tackle it that way. I actually have to do this to a ramcharge I bought. I did the same with my W250 restore.
flyboy129's Avatar
This is my crew that I ended up replacing the whole rood section on.
Re: Quicksilver project (85 crew cab) Roof replacement!!! - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
Scroll down to reply #12 to see the insides of the roof. There are actually 4 layers in the roof. Outer skin, inner front brace (what you are seeing inside the sun visor holes), drip rail, and inner skin.
I think bcron has the best idea for rust proofing/prevention on these rigs. He simply cuts out the inner skin around the stamped designs on the inside of the cab, then cleans and treats with primer/etc.
Old Jan 11, 2016 | 12:38 PM
samiam4's Avatar
Was the inside painted in these ??
I don't have a rust problem. Just trying to shore things up. Wurth makes a spray able wax for rust proofing closed panels. I was thinking adding holes maybe 1/8 inch.
Removing inner panel is beyond scope.
Let me know the wand you are using please. Will look more.
Will 80mil sound deadING fit above the headliner? Seems booming with a tap.
M
Old Jan 11, 2016 | 01:13 PM
bannerd's Avatar
M
They were not painted. Anything is better than nothing, I like the eastwood stuff because of the creep it has. We used the wax from wurth (big fan of the SKS underbody). Unfortunately when the -30F or -40F cold hits the wax falls off and becomes fragile. If you live in the south, no worries.
Amazon.com: Fluid Film Spray can Extension Wand: Automotive Amazon.com: Fluid Film Spray can Extension Wand: Automotive
The small ones are great and easy to seal up with a mig.
Old Jan 11, 2016 | 04:21 PM
gyman98's Avatar
If you are using the plastic trim piece over the windshield you can spray through the screw holes
Old Jan 11, 2016 | 05:56 PM
mknittle's Avatar
M
Something like this maybe.
Eastwood Internal Frame Coating 14oz Aerosol
Old Jan 11, 2016 | 06:36 PM
jerseybud's Avatar
Heres a good one
1stGen.org ? View topic - Club cab drip rail over windsheild rust rot repair
And this guy copied the first one
1988 W-100 - 360 magnum swap- running - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram
half way down
Old Jan 11, 2016 | 06:43 PM
jimbo486's Avatar
I'm going to be doing this to my single cab sometime soon.
Now onto the interior roof panels. Here's what they looked like before.
I wanted removable panels like CE TEX has done in his truck. So out came the cutting wheels.
Then it was sand and pain the inner roof. I also masked and painted all the roof and pillar areas white too.
Old Jan 12, 2016 | 12:18 PM
flyboy129's Avatar
This is what I was referring to^^^
Also, don't overlook the initial cause of most roof and driprail issues. Dried up seam sealer that is coming out of the gutter. Chisel all of the old out, wire brush it, prime with a quality primer, then reapply new sealer.
Old Jan 12, 2016 | 01:24 PM
samiam4's Avatar
I'm painfully aware of the drip rail issues. Mine, previous owner had hit something on a corner and it was leaking. Roof was rusty, so I took it all down to bare metal.
I sanded it all and with all the seam sealer removed- you prime it first, then seam sealed it with the fancy stuff, then top coated with some leftover Kirker single stage white urethane.
Michael
Old Jan 13, 2016 | 03:01 PM
james1's Avatar
Smile from a drip rail repair thread in 2011...
seam sealer recommendation I posted four years ago:
Originally Posted by james1
I just had a good local body shop repair mine. He used a 2-part epoxy product from Rubber Seal (a division of Teknol) called Self Leveling Seam Sealer MRS-7204. It's the OEM product nowadays on a number of Ford products.
Two Component Static Mix Materlals - MRS-7204
It certainly looks a lot smoother than the OEM Mopar stuff from 1993; chemical engineering has come a long way since then.
Old Jan 13, 2016 | 03:27 PM
mknittle's Avatar
My only concern is where the driprail goes vertical behind the door. will the sealer run down the side of the truck?
Old Jan 13, 2016 | 04:31 PM
james1's Avatar
Question
I didn't watch the body shop do the work; next time I speak with them I'll inquire about whether or not this is an issue and, if so, how to deal with it.
1. Does anyone have a strong opinion as to whether Fluid Film or Eastwood coating is the superior product for this application?
2. Is there any reason I could not use an aerosol can of Fluid Film or Eastwood coating with a wand -- applying the product from outside the cab via the cab marker light holes in the roof?
TIA
Old Jan 13, 2016 | 04:59 PM
TIA
I have used fluid film cans with the wand to spray in the cab light and sun visor holes on several 1st gens, to ward off the windshield rot.
