lock up?
Old Dec 2, 2009 | 08:42 AM
peobryant's Avatar
Originally Posted by T Lozano
you mean that I must have the 518-727 or that it won't fit the truck? Oh and if its upgraded and fits is the 618 (47rh) a lock up?
Your truck is a '93, so you have a 518. Yes a 47rh will fit, and yes it is a lock up transmission.
Old Dec 2, 2009 | 06:01 PM
T Lozano's Avatar
Great, hopefully I can find one ready and I won't have the expense of aftermarket parts, now that I am in need of turbo also. Thank You all for the info.
Old Dec 2, 2009 | 06:11 PM
sdstriper's Avatar
Have you tried a decent torque converter yet? A good converter is a world apart from the OEM pile...
Your going to have a considerable amount of money in the 47RH conversion. It is not a plug and play swap either, I would check the stickies and do some homework.
Old Dec 2, 2009 | 11:42 PM
T Lozano's Avatar
Will do
Old Dec 3, 2009 | 12:09 PM
unixcowboy's Avatar
IT's not ?!?!?
Mine was - I plugged in $$$$ and then played with the result
Seriously tho the trans rebuild will set you back 1500 - 2200 depending on how far you go.
The install requires a 94-95 engine adapter and starter. You will have to move the rear trans mount toward the rear ~ 1". My driveshaft had enough spline showing that it was all taken up after the install, could be due to the split driveshaft; I've heard some have had to shorten the driveshaft.
Old Dec 5, 2009 | 11:53 PM
T Lozano's Avatar
Question
When changing engine adapter, would I need to zero it in like the flywheel housing on a NTC 350
Old Dec 6, 2009 | 06:57 AM
archer39's Avatar
i don't know anything about the NTC 350 but changing the adapter plate is just a matter of unbolting the old and putting the new back on. It can only go on in one position.
Old Dec 6, 2009 | 08:21 AM
T Lozano's Avatar
I see, on a big Cummins I have to use a dial indicator mounted on the crank and touching the housing to zero it in just thought I'd ask Thank You.
Old Dec 6, 2009 | 11:51 AM
Boatnik's Avatar
If you haven't done it already, don't forget to upgrade the flex-plate. The second gen. plates are a lot stronger and don't break as easily.
Old Dec 6, 2009 | 01:00 PM
The_Head's Avatar
I read somewhere the new 6.7 68RFE flexplates are pretty awesome as well.
Old Dec 6, 2009 | 04:58 PM
sdstriper's Avatar
Originally Posted by txs
I don't know if the big cummins flywheel housings are doweled, the 3bt, 4bt,6bt series motors are doweled in 2 of the mounting bolt holes. Since the auto trannies have an integral bell you have to have a bare case and sweep the pump bore to check the register. The chryco gasser motors had a solid dowel and offset ones were available if needed, the lakewood bells were notorious for being off on the register, the b series cummins have a hollow dowel so the mounting bolt can go through it, don't know if there are offset hollow dowels.
A few years ago I saw mysteryman comment on this.
JKM
Sep 23, 2007 11:38 AM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
