lock up?
Guest
Posts: n/a
Sure can, but. The L/U converter is an inch longer than the non lockup converter so you need second gen flywheel housing and starter, so most folks would ruther use a 47 as there were also other upgrades. If interested in 518 lockup you would need a lockup input shaft, reaction shaft support, and valve body. The 727 can be converted over also but it's a little more complicated.
Guest
Posts: n/a
ps, the 727 lockup conversion is only more complicated because of the valve body, chryco never made a 727 electrical controlled L/U valvebody, I would try the hydraulic controlled body. I THINK you could use one of the 904 electrically controlled valvebodies with a little work, these were called part throttle unlock by chryco. I'm working on one of these bodies right now, when it's done next year I'll build a 727 diesel lockup. Funds for the converter is the holdup right now.
Guest
Posts: n/a
whether you buy a 47rh or convert a 518 if funds allow buy an aftermarket hd input shaft, the hollow lockup shafts are weaker than the equivalent non lockup shafts. I know of 2 local boys who twisted off the stock lockup shafts in a stock truck, both times it ruined the pump too. Some people call them billet shafts but the stockers are also billet shafts, then carburized (case hardened), all that means is it's whittled from a solid chunk. The aftermarket ones you want are alloy, something like 4340 chrome moly. 4320 and carburized would be better but don't believe they're available.
i am running a stock input shaft without any issues yet. Dave Goerend said that a stronger input shaft is not really needed unless if your over 400 hp and doing a lot of boosted locked up launches. It is a good idea to upgrade if you can.
I was looking into the A618 for a possible transplant am I on the right track as far as being able to stay stock with little to no upgrades. Cause I just checked my turbo about an hour ago and found a sloppy shaft so there goes my transmission funds
stupid me.. had 47rh on the brain for so long thats all i think about in automatic terms
