Limited slip rebuild problems
Old Feb 14, 2011 | 10:06 PM
93 high hopes's Avatar
So I recently (about 10 months ago) re-built my Dana 70 limited slip rear and now I don't have the LS action in the snow.
Followed the directions and everything, but I didn't use thread locker on the diff housing or the mounting brackets, didn't see any reminisce of any when disassembling, has anybody else not used thread locker on this application?
No grinding when turning as when the prior disks were bad, just no LS.
Any ideas???
Almost forgot, when installing the axles back after the re-build, it was EXTREMELY hard to get them to seat all the way in the diff, thought that was weird, almost as if the diff housing had deformed from the new clutch pac.
Old Feb 15, 2011 | 07:36 AM
theidlemind's Avatar
Not good.
Remove the cover and see what's in there. Sludge from burned clutches?
Fluid level, no-slip additive?
I'm curious because I have this job ahead of me soon and I just want to do it once.
Keep us posted.........
Old Feb 15, 2011 | 08:22 AM
custom_delux's Avatar
What kind of oil did you use? synthetic oil will turn the clutch packs to mush
Old Feb 15, 2011 | 09:13 AM
No synthetics, but did use the LS additive.
My thoughts are that maybe the bolts that keep the diff housing together may have come loose, releasing the tension on the clutches themselves.
Just a thought, no evidence of this.
flatrocktruck
Jul 31, 2010 08:10 PM
mysterync
Jun 16, 2008 06:33 AM
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
Srigs
Nov 13, 2002 09:30 PM
