Limited slip additive
I picked up a factory limited slip for my truck but I haven't installed it yet. What is the best additive to use for the limited slip?
pepboys carries royal purple don't know about autozone. I am running kendall limited slip additive (what the local parts store carries) with no problems so far. No chatter and it grabs good.
Location: A 5th dimension, beyond that which is known to man.
1 Post
if i recall correctly..
if you do any towing you probably should run 75/140 and synthetic if youre in a cold area.
75/90 if you use your truck as a commuter to help with milage.
I know everyone has their own opinion. When I ordered my diff from Randy's ring and pinion they told me royal purple was a bad idea. They said it didnt work well with the clutch faces and caused premature wear or something like that. They recommend using a conventional gear oil. To each thier own though. RAM
1 Post
i dont see many reasons to run royal purple. a lot of issues have occurred. more hype than anything. i try to spend my synthetic oil money on redline oils.
There was a review paper compairing many diff oils. I think Amsoil came out on tops and Redline- heavy shockload was quite good. I run the Redline product in my Torsion-gleason diff with good results.
RP would be great as it has the additive in the fluid..
