lift pump question
lift pump question
I need to replace the lift pump on my 93 W250. I picked up the pump a few days ago from NAPA. It says made in South Korea on the box, which probably isn't good
? Anyway; I misplaced my FSM a while back, and was hoping someone would know the torque specs for the lifter pump bolts? Also; what type of gasket sealer is best to use on the included paper lift pump gasket?
I have always used Permatex 2 Form-a-Gasket Sealant NON-HARDENING for any such similar applications.
I ?think? this is the same stuff as the old tried and true Mr. Gasket stuff.
I smear a thin coating of this stuff on BOTH sides of the gasket and any subsequent future removal of the part results in a clean release of the gasket, allowing it to be reused AND no scraping needed.
As for the mounting bolts, just past snug is enough.
Too much and they will snap.
I have on hand a bunch of 8mm x 1.25 ?I think? studs that I intend to use to replace all the lift-pump and water-pump bolts in all of our engines, thus making it a lot easier to line things up.
I suggest you procur a set of studs/washers/nuts when you buy the new pump.
If this is an un-molested factory-original style set-up, I suggest you also pick up a few feet of new diesel-rated fuel-hose, ?? 30RC I think ??, (those numbers may not have anything to do with fuel-hose; they just jumped into my head).
I am unsure if factory issue hose is 5/16 or 3/8; best to just get some of each, plus new clamps.
This new hose is to replace that short section between the frame-rail and lift-pump.
While you are at it, there is also a short section at the fuel-tank pick-up unit.
These are notorious to get all dry-rotted and crackledey and develop an air-intrusion leak, if not just break plumb off and shut you down somewhere inconvenient.
Yes; this is a stock OEM setup. I have to see if I have the time to get the line back to the tank replaced. I need to get the old girl back on the road in about a week, in order to move some tables etc. out of a storage unit
Would you or anyone else have a Dodge/Cummins part # for the OEM upper hard fuel line with the 17mm banjo bolt fitting, as well has the lower hard 90 degree fitting - which snaps into the fuel line. I guess I will need a Lyle style fuel line tool, in order to disconnect the lower line on the lift pump? Also; where's the best place to get fuel line - JEGS/Summit??
Bear,
Would you or anyone else have a Dodge/Cummins part # for the OEM upper hard fuel line with the 17mm banjo bolt fitting, as well has the lower hard 90 degree fitting - which snaps into the fuel line. I guess I will need a Lyle style fuel line tool, in order to disconnect the lower line on the lift pump? Also; where's the best place to get fuel line - JEGS/Summit??Since every last one that I have ever worked on has only ever had a plain old 1/4-NPT X hose-barb 90* EL and a plain old hose-clamp at that lower fitting, I just assumed they all did.
For just plain old black rubber fuel-hose, I just buy it by the roll (or by the foot) at NAPA on account of their hose being GATES brand.
A much better option than the factory hard-line is to forget the banjo fittings.
The top lift-pump fitting should be 14MM x 1.5 --- use a -06 JIC metric adapter there.
All the rest of the fittings, both sides of the filter and the injection-pump inlet should be 12MM x 1.5 --- use a -06 metric adapter at the filter head.
Use a -06 JIC x straight hose-swivel at the lift-pump.
Use a -06 x 90* hose-swivel at the filter.
Complete with a length of 3/8 rubber hose to fit.
The JIC fittings and flexible hose are much easier to work with and will not develop vibration cracks like rigid hard-line will.
Thanks for the info on the JIC fittings! I will pick those up and get some fuel line from NAPA. Yeah; the lower 90 degree fitting on my 93 W250 lift pump has a fuel clip type connection, no hose clamp. If I had a digital camera I would take a pic of the clip, but my FUJI pic camera died awhile back. Thanks again for the help!
BearKiller or anyone else,
I just got around to replacing the oem fuel line, with 3/8" Gates fuel hose. I am going to replace the oem fuel line from the fuel filter to the fuel pump next, with 3/8" fuel hose as well. When I have the time, I will probably drop the tank and replace the suction line as well - Per BC in the sticky.
I am pretty sure there is no need to replace the oem return line? Would there be any benefit to changing this out to 3/8" fuel line as well? My plastic return line is still in fairly good shape. I don't think BC did, when he upgraded his fuel line and suction line to 3/8." I may be wrong though?
The return-line has no pressure on it to speak of, UNLESS one is running a bypass regulator, in which case a larger diameter return-line would be called for.
I would leave the plastic line alone, but I would go ahead and replace the sections of rubber line, 1/4" I think.
Bear; Marc etc.,
I finally finished plumbing my 3/8" fuel lines - from the tank to the lift pump, then from lift pump to fuel filter, and on to the fuel pump.
Now; I need to tighten the JIC6 straight barb fitting on the front of the fuel pump. I am having a hard time getting an open end wrench in there. Not a lot of room between the bottom of the pump and the timing cover! Do I need to loosen the fuel pump and rotate it, in order to get a wrench in there? Or; use either a crows foot with a socket extension and ratchet wrench. Or; use a stubby wrench? Any help is appreciated!
