lift pump install today
Old Jan 15, 2007 | 02:54 PM
hoghead's Avatar
Got rained out at work (concrete finisher) so I put on my lift pump. Everything went well ,I bled out the air above fuel filter. I dont know if it is my imagination or not but the small leak at the fuel heater turned into a bigger leak. I am assuming that the new pump is holding the correct pressure and not bleeding off like it was before when it leaked causing more pressure thus more of a leak.I have the parts to fix the fuel heater leak arriving tomorrow from cummins. The big question is do you think i will gain any better throttle response,horsepower,or fuel mileage.
Old Jan 15, 2007 | 05:25 PM
BC847's Avatar
1st Generation Admin
Smile
Not being a smart-tail or anything, but fixing the fuel leak will improve the MPG numbers alone.
Assuming it is/was a small leak then you may not see any improvement otherwise. Then again, if the old lift pump was marginal at best then perhaps you will see a small top end improvement simply due to no longer going to 0psig fuel pressure to the IP at WOT.
Txwelder
Nov 26, 2025 01:53 AM
TIMMY22
Jan 2, 2007 06:26 PM
digbog
May 25, 2006 06:55 PM
stillsmokin
Apr 4, 2006 02:23 AM
Txwelder
May 19, 2005 06:10 PM
