NV4500 Driveshaft Question
Old 02-19-2018, 08:49 PM
akjw's Avatar
Real quick esoteric driveshaft question. Feels like a long shot but I'm sure one of you gurus has an answer. Helping a friend with a nv4500 swap. Hoping to get all the parts together before hand. Wondering what the length is on the rear driveshaft for a 4wd Regular cab w350? So from the np205 rear output to the rear diff. If anybody has a length on theirs or someone just randomly knows the length, id really appreciate it. Thanks!
Old 02-20-2018, 03:11 PM
u2slow's Avatar
I don't have a std cab 4x4... but the 727/5spd (G360) trucks apparently have the same length shafts, and the NV4500 is close-ish.
Its the auto OD trucks where the front (longer) and rear (shorter) differ by several inches.
Hope that helps a little.
Old 02-20-2018, 03:30 PM
Received 2,392 Likes on 1,576 Posts
Like u2slow said you should be able to re-use getrag or 727 driveshafts with a NV-4500 swap.
I used a 727 front and a Getrag rear two piece driveshaft on my crew cab swap when I put in the NV-4500.
Old 02-20-2018, 03:44 PM
MrFusion's Avatar
I think that there is less than .5" o fdifference with the NV4500. I swapped one in to the rig (previously G360) in my sig and everything bolted up no problem.
Old 02-21-2018, 06:45 PM
death row dave's Avatar
I’m sure that is correct also , should work fine as wine
Old 03-05-2018, 10:44 AM
akjw's Avatar
Hey everybody. Really appreciate the responses. Ive been out commercial fishing and haven't been in service to respond. Thanks a lot for the info!
Vader93
01-12-2015 09:31 AM
SilverSootXpres
03-23-2010 07:18 PM
signature600
09-18-2005 02:18 PM
98 2500
02-17-2005 02:00 PM
Quick Reply: NV4500 Driveshaft Question
