KPD and case bolts fix 91.5 D 250?
I have a 91.5 intercooled 2wd D250. I have been reading that the timing case bolts are prone to backing out due to the factory not using loctite on them. This has me worried more than the KDP. I will make a homemade tab or peen the hole for the KDP fix.
Unfortunately I do not have a shop to do this in so it will be a shade tree job. I am hoping to do it as quickly as possible since it seems to rain non stop here.
I plan to take the radiator our so it is easier to get to everything.
Is there a way to do this without removing the fan clutch? It seems to be hard to get off.
What special tools will be needed to remove the harmonic balancer and fan clutch?
Should I use red or blue loctite on the case bolts?
How do you guys clean the bolt holes before adding the loctite?
What is your opinion on the Fel pro crank seal and TC gasket vs Cummins? I am not sure if I want to deal with a RTV bead gasket on such a large case.
Is it best to install the seal in the TC before installing the case on the engine?
I can not think of any other questions. Did I miss anything?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
I used the Felpro kit on mine. I haven't had any problems with Felpro over the years. I installed the seal in the cover on the bench. I think it is eraser then doing it upside down.
I use blue locktite and just a little as too much won't cure.Also brake cleaner works good to get the oil out of the bolt holes.
and this may help locate the case bolts. one hides really good
https://s3.amazonaws.com/cdn.genosga...erDowelPin.pdf
RamDodgeSam
Feb 25, 2017 10:29 PM
DC199512V87
Oct 17, 2011 11:37 AM
roughstock
Apr 22, 2009 10:45 AM
steven
Aug 14, 2006 02:49 PM
