Knocking In Motor Help!
Old Jan 24, 2007 | 07:03 PM
dodgec68's Avatar
My truck has been knocking slighty when I accelerate sence I bought it thanksgiving of last year. Was not really noticable under load until today. after work I started it and it ran really rough until it warmed up and now I can here it all the time. not really loud but something is defenitly wrong.
any sug. would be helpful
i.e. valves, bearings
thanks jesse
Old Jan 24, 2007 | 09:41 PM
Raspy's Avatar
Not much to go on here but if it knocks less under load and runs rough at idle it sounds like an injector with a bad tip. If you look at the exhaust while idling you might be able to detect puffing. Where one cylinder is not burning clean and sends out a smoke signal. Puff puff puff.
Wetspirit
Old Jan 25, 2007 | 09:00 AM
efbeason's Avatar
I had my injector pump rebuilt about three months ago and I kept hearing a small knock when I accelerated. In the end the problem was the pump timing. The mechanic who rebuilt the pump told me he advanced the timing on the pump when he put it back on. I backed it off a little over 1/8 inch (but not hardly 1/4) and it runs smooth as silk now. Hope this helps!
Old Jan 25, 2007 | 10:03 AM
Redleg's Avatar
I might get the valves adjusted if it hasn't been done. Maybe some maintenance on the fule return valve.
Old Jan 25, 2007 | 01:29 PM
dodgec68's Avatar
did the knocking get worse aroud 2300 to 2500 rpms? that is when I can really hear it. any Ideas on the rough Idle/or missing when its cold. It also vibrates when I hear the knocking, does it most in 4th and 5th.
Old Jan 25, 2007 | 02:54 PM
efbeason's Avatar
My truck did not miss when cold. No, it did not get worse at those RPMs. I could just hear a knock when I mashed the accelerator. Holding it steady it ran a little rougher than it does not but no knock.
Old Jan 25, 2007 | 04:03 PM
Could be air in the lines. They will knock and run terrible with an air leak.
Old Jan 25, 2007 | 06:22 PM
tboling's Avatar
Mine had a small knock, than it became worse. A cam bearing whent out and broke a lubo off the cam shaft. I hope it's just a fuel knock.
Old Jan 25, 2007 | 07:19 PM
dodgec68's Avatar
air in the fuel lines. would that slowly get worse over time, and what about the rough idle when I start it? because after the truck warms up it smoothes out to a point. also haven't had any horse power loss. I will check my lines though.
Tmello401
Apr 28, 2014 05:38 PM
bjytech
Nov 9, 2008 11:32 PM
G-NOTE
Jul 26, 2005 07:07 AM
turbov6joe
Sep 2, 2004 10:44 AM
local601
14
Jun 1, 2004 12:20 PM
