Knock I Think?
Old May 27, 2005 | 06:12 PM
sho_shane's Avatar
Would I hear a rod knock when the truck is just in idle. Also the noice is not all ways there some times I dont here it and some times a do?
Old May 27, 2005 | 06:19 PM
No, you would not be likely to hear a rod knock at idle.
Most likely it's just an injector related knock. You may have an injector or two that pop off early, causing a little knock. You could take it to a truck shop and have them listen and see what they think. It's very hard to diagnose a noise you can't hear.
An oil analysis would let you know how things are going inside the engine. It'll set your mind at ease to know what's going on.
Old May 27, 2005 | 06:23 PM
sho_shane's Avatar
hey thanks for all the help and all the time
Old May 27, 2005 | 06:28 PM
sho_shane's Avatar
One more Q is it ok for me to drive my truck till I have a chance to get to the shop?
Old May 27, 2005 | 06:34 PM
I think so. The fact that it's intermittent makes me think it's nothing internal or really bad.
Old May 27, 2005 | 06:52 PM
sho_shane's Avatar
TO me its pretty bad like I said some times I dont here it BUT most of the time I here it. When im at a stedy higher RPM I cant hear it. most guys tell me it sounds normal and theres one guy at a shop in town that told me it mite be an internal knock. But he only works on fuel systems so im not sure if he knows what hes talking about I just dont know
Old May 27, 2005 | 07:28 PM
Do the guys that are telling you it sounds OK have experience with diesels? If so, keep driving it, and send an oil sample in to be analyzed. If the analysis comes back OK, then it's not an internal problem.
Old May 27, 2005 | 07:49 PM
sho_shane's Avatar
What do you mean oil sample in to be analyzed? I dont know what that means?
Old May 28, 2005 | 03:40 PM
http://theoildrop.server101.com/whatisoilanalysis.htm
Old May 31, 2005 | 11:58 AM
efbeason's Avatar
My truck began having what I thought was a knock. As I kept driving it, it got worse and worse. After about a coule of months, it started doing it even when I was idling. After close inspection I found that two of my injectors had backed off and was letting two of the cylinders lose compression and that created what I mistook for a knock. I tightented all the injectors this past weekend and after that I have not heard anything except the sweet purr of that Cummins! I don't know how many miles your truck has but mine has 259,000. Hope this helps. Might be worth considering before you spend a gob of money!
Old May 31, 2005 | 03:38 PM
Nuttymopar's Avatar
Could it possibly be Valves that need to be adjusted? When was the last time that was done? They recommend about ever 24,000 miles though it really wouldn't knock that loud, I don't think.
I think either injector or something simple. Rods in these trucks just don't go that much. They are known to go, but it takes it somewhat to get them to go.
Old May 31, 2005 | 10:08 PM
DODGE 92's Avatar
first thin id do is check oil pressure or buy a gage its only 50$ and easy to install
2 my truck did same thing i had injectors pop tested put some new washers on them o\and voila
injectors arent hard to take out you can do it and it woul give you a good idea on that truck and take compression while your there it wont hurt to no if you got q on how to just ask i did all that 2 weeks ago
Old Jul 3, 2005 | 10:30 PM
AlK's Avatar
AlK
sho_shane,
Did you finally figure out what the knocking sound was in your truck?
How about an update.
Old Jul 4, 2005 | 08:47 AM
sho_shane's Avatar
Still dont know anything. Had my injectors checks one was bad I replaced it and the knock still rolls on
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
