kind of random.. anyone have one of these??
I pulled the bed of my truck today to get ready for some spring work, brakes etc. I new the frame was a little iffy considering being from maine and all. luckly it wasnt to bad, probably weld some 3/16 plate on it in spots where the frame is thinned due to rust.
the problem I have is the cross members are toast the one in the back of the truck is gone literally... previous owner used tow a boat and dunk the rear in the ocean
the cross member that runs over the top of the tank is about toast as well...
the rear Im planning on welding some square stock.. no biggy, but I don't know what to do about the front one...
anyone happen to have one by any chance???
hmmm... my cousin has welded angle iron onto his frame before with no issues. I remember they were not super thick. Maybe the thickness of an old fold up bed frame or something.
Lots of those thin angle iron beds in the Blue Hill/Surry transfer station bradshaw. I was eyeing them for some other projects and decided they were too thin. Probably just right for what you want.
You may get the flex you need from a bed frame but the crossmembers that were in the truck from the factory were close to 3/16" thick. I dont think there will be enough stregnth to them.
I lucked out when I reworked the frame on the 93. All the cross members were mint. On mine the rails and hangers were spent. You might want to check the lower frame web under the plastic shield that protects the fuel tank. Mine looked like a steak knife there.
Welding a frame back together is one thing but cross members are bolted or riveted in for a reason. I have welded many cross members on big trucks at work and they always seem to break again. The frames on these trucks are not very rigid at all they flex around quite a bit. Just my .02 it is your truck fix her up how you see fit good luck getting her going.
Bwest99svt
22
Oct 23, 2007 09:03 AM
tacook
Dec 25, 2005 01:01 AM
midwestdually
Dec 6, 2004 07:35 AM
