just want to make sure I understand this.
Old Nov 16, 2011 | 03:15 PM
93-12Smoke's Avatar
Pulling my injector pump tonight to rebuild it tomorrow. From everything I have read it looks like you just pull the pump and don't worry about timing during removal. Then when you reinstall it you bring the motor to TDC and install. Is this correct?
Old Nov 16, 2011 | 03:35 PM
fatt's Avatar
Almost. You don't need the engine at TDC. If the VE shaft slides into the gear with the keyway lined up the timing is correct.
Old Nov 16, 2011 | 03:56 PM
93-12Smoke's Avatar
Sounds good.
Old Nov 16, 2011 | 04:42 PM
93-12Smoke's Avatar
Just line the timing mark on the pump back up with the mark on the case?
Old Nov 16, 2011 | 04:48 PM
Yea or put the mark on the pump above the line on the case a little bit for more power
Old Nov 16, 2011 | 07:52 PM
93-12Smoke's Avatar
Yeah, gonna bump the timing while I'm there
Francis Parmer
Mar 4, 2013 04:35 PM
05CTDN8
Jan 10, 2007 06:46 PM
Smokeman
Mar 24, 2006 11:24 PM
John Rodriguez
Sep 28, 2005 11:46 AM
