Just installed governor spring, top speed only 77 mph...
When I bought the truck it would do 85 if I wanted it too. I'm wondering what we did wrong. We had to remove the TPS and reinstall it because it wouldn't line up right. We also had to mess with the idle screw a little to get it to idle.
Acceleration is great, boost is 20 psi max, EGT's only got up to 800* F.
It doesn't like to shift into OD either. You really have to gun it and get up to about 65 mph until it shifts in OD. I checked ATF and it was a little low. Filled that and it still does the same thing.
I had to fiddle with my throttle shaft indexing, low idle adjustment and high idle adjustment to get things right when I installed the 3200 spring. I even had to shorten up the throttle rod a bit.
dodgetrucker75
38
Jan 10, 2012 10:17 PM
92smokin blacky
Oct 3, 2010 07:21 AM
treemonkey
Jun 17, 2009 02:06 AM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
