Just can't figure out why my truck would have blow-by... :)
Old Oct 21, 2023 | 07:24 PM
mhuppertz's Avatar
Old Oct 23, 2023 | 08:35 AM
With POD injectors and a tuned pump, I would assume the Pyro gauge would really be the one too be looking at in the video.
Old Oct 23, 2023 | 08:58 AM
mhuppertz's Avatar
Big turbo, big intercooler, EGT's don't get much above 900 (after turbo). I was just making a joke. I can hit 90 in 4th before I have to shift into 5th. The truck hasn't had an easy life with an almost senior citizen delinquent pulling the levers and pushing the buttons for 460k miles.
Like to see pictures of that "'85 W-350 crew, '90 12V/NV-45, HX-35, 24V intercooler, tubes, boots and I-horn, airbags over springs at all 4s, 3.07s"!
Old Oct 24, 2023 | 04:49 AM
KRB's Avatar
KRB
Dang, that's fast. What are your RPMs at those speeds?
Old Oct 24, 2023 | 09:55 AM
mhuppertz's Avatar
I redline the 3,200 spring at 90 mph in 4th, 5th buries the needle.
Old Nov 6, 2023 | 10:57 PM
JesseOkeefe's Avatar
Blow-by in your truck could be caused by several factors such as worn piston rings, cylinder wall damage, or a malfunctioning PCV system. It's important to diagnose and address the issue to ensure optimal engine performance. Consider a compression test and inspecting your PCV system to start.
Old Nov 7, 2023 | 05:36 AM
PCV huh?
Old Nov 7, 2023 | 11:10 AM
BHD's Avatar
BHD
PCV huh?
Mine must be stuck, that would probably explain the odd vacuum readings i see when plug the ECM into the scan tool.
Old Nov 7, 2023 | 05:50 PM
KRB's Avatar
KRB
I think I removed my system when I bought the truck? It's probably in the pile with the distributer I took off at the same time.
Deezil
Sep 4, 2015 12:07 AM
Jim5870
Aug 19, 2013 10:04 PM
ATP-Mike
Competition / Pulls / OffRoad
Mar 21, 2013 05:16 PM
iker42
Apr 27, 2009 07:53 AM
taterfarm
Sep 18, 2008 08:39 PM
