Jerking when Stomping on the throttle
Old Nov 18, 2008 | 02:54 PM
airforce27's Avatar
I have a 92 W250 4x4 5-speed, and when i go to stomp on the gas it will jerk and if i let off really quick, kinda like if a Universal joint was going bad. but i look at them and they seem to be alright considering if i checked right. im thinking maybe the transfer case? what do you guys think? any hel p is appreciated, Thanks
Old Nov 18, 2008 | 04:11 PM
NotEnufGarage's Avatar
Checked your clutch and/or throw out bearing lately?
Easy solution ; don't stomp on the loud pedal and let of the clutch slower. It's a 5000+ lb truck you're driving, not a dragster.
Old Nov 18, 2008 | 04:25 PM
BC847's Avatar
1st Generation Admin
Look real hard at the rubber components of the engine and transmission mounts.
Old Nov 18, 2008 | 04:43 PM
Also check the cross pin (if open diff) or diff clutches.
Old Nov 18, 2008 | 09:39 PM
dragrdan's Avatar
Wheelhop, maybe? I have a 93, and it will hop if it loses traction. Hate the lift blocks.
Old Nov 18, 2008 | 10:19 PM
gear jammer 91"'s Avatar
Mine does the same thing, but it doesn't take a lot of throttle to cause it. It's most noticable when I let off the throttle abruptly at freeway speeds and then get back into it. My u-joints are good, the clutch is new, and i don't have any slop in the drive line, when twisting it by hand. If it was a bad motor or tranny mount wouldn't I see my shifter move from side to side as this was happening?
To fix it right now, I just try and drive and shift in a way that doesn't cause the clunking.
Kiff
Jun 29, 2009 06:33 PM
iweb
Oct 16, 2005 07:19 PM
Big Jimbo
Sep 1, 2005 08:27 AM
NO1B4ME
Jun 29, 2005 06:53 PM
gsim1228
May 23, 2004 09:15 PM
