internet dyno my mods
Old Oct 23, 2010 | 12:38 AM
Lucas1's Avatar
ok iam looking for 400+ hp 1100+ ftlbs torque
what you think
i have whats in my sig plus a few items on the bench going in in the next few weeks.
got
goerend converter
he351 with 4" downpipe
some more pump tuning
reset on valves
bump the timing some more
cooler tubes
powerstroke intercooler
changing to a amsoil filter with some sort of cold air intake.
Old Oct 23, 2010 | 06:12 AM
TLRMAN's Avatar
300 +0/-40
Old Oct 23, 2010 | 08:21 AM
1STGENFARMBOY's Avatar
Thats an awsome truck.... I think if you spray some w/m you could be getting close, but without maybe 325-340 hp and who knows on torque its harder to guess than hp, maybe 800-850
Old Oct 23, 2010 | 08:47 AM
14racing's Avatar
Pretty sure your going to need bigger injectors to see those kind of numbers. I don't think at 400hp your gonna see 1100 ft lbs either.
Old Oct 23, 2010 | 09:32 AM
GIT-R-DONE's Avatar
255/660 is my guess
Are you going to go dyno so we know what it actually is ?
Old Oct 23, 2010 | 09:36 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
254hp-569ft.lbs on a dynojet.
maybe less if you have a junk transmission.
what kind of fuel supply do you have?
Old Oct 24, 2010 | 05:49 PM
92smokin blacky's Avatar
I bet around 290-320 hp, and about 700-800 ft lbs.
Old Oct 24, 2010 | 06:48 PM
archer39's Avatar
agreed, and the only way your going to see close to 400 hp with that turbo is if you advance the timing a lot. Then your not going see even close to 1000ft lbs of tq. Your going to need more air and fuel to see the numbers your looking for.
Old Oct 24, 2010 | 07:09 PM
BC847's Avatar
1st Generation Admin
You'll need more fuel and air.
Old Oct 24, 2010 | 08:57 PM
Lucas1's Avatar
ok so more air an fuel...
i will dyno it in the spring at dyno days at bd if its not stupid busy
will the he351 support 400 with enough fuel..or egts going to be stupid??
Old Oct 24, 2010 | 09:34 PM
93flatbed's Avatar
I got a 351. It doesn't get hot. But it gets way out of its map range!
Old Oct 24, 2010 | 10:41 PM
GLHS's Avatar
Not on a ve pumped 12 valve with an unported head. Three whammys against ya!
Old Oct 25, 2010 | 10:40 AM
rebal's Avatar
If i made a guess it would be 250/600 my sons 91 hits 407/900 with PODs / twins and w/m EGTs stay at 950
you will need more fuel and more air to get to 400hp
Old Oct 25, 2010 | 05:09 PM
Lucas1's Avatar
****...at least your honest
i should have bought the blown p pump motor i found for $700
before you send me to the search button
point me to suggested inectors...
industrial injection??
dynomite diesel stage III??
90-100hp with a little w/m if the egts get too high.
i tow alot 8000lbs plus.......i will keep spending money till i can outpull all my buddys newer trucks with the chip
but not tell them the mods
Old Oct 25, 2010 | 06:31 PM
Are you getting your power to the ground yet?
Personally I'd leave the engine alone and think hard about what you wanna do about your trans. Build your 518 and put a converter in it......Swap to a Rebuilt 47RH lockup and put a Converter in that and have lockup but you gotta find a 47RH core and stuff needed to swap.....Put a shift kit in the 518, converter and wait for it to blow??
Or go to a 5 speed manual......
If you tow 8K I'd build your trans and leave it alone Otherwise you're gonnna have to drop dough on a turbo and airflow upgrades. 8k+ is alot of weight for an Overfueled 12v. You're gonna be on that W/M button like flies on poop trying to keep them under control.
BTw, your truck looks awesome.
tristan21
Jun 19, 2007 04:57 AM
butchera
Jun 10, 2003 12:21 PM
drawson
Mar 17, 2003 06:24 PM
