Intake manifold air horn
Is there an aftermarket air horn that routes the hose to the front rather than the stock side feed? My build is unique in that I have room above the engine but tight on the driver side. I tried rotating the air horn but the four bolts are not symmetrical; the best I could do is have the two opposing corners bolt in right but for the two others I may have to notch just so the bolts can go through. I think the gasket will still keep it air tight.
Banks made one but I highly doubt you could source that piece. Also there are plenty of Cummins pieces from applications other than Dodge trucks that point different directions and are of different outlet sizes. A good engine/core junkyard maybe.
Ottwa yard trucks use a front facing air intake horn on the 12 valve trucks.
I think MIDon used a front facing air horn off a FL60 on his Travco motor home swap. He couldn't use the side facing air horn due to engine cover clearance.
Mopar_Man
18
Sep 23, 2008 08:18 PM
natlchamp2k4
Mar 13, 2007 05:47 AM
BA05'CTD
Jan 7, 2007 03:08 PM
