New intake horn/manifold
Old Sep 18, 2008 | 03:22 PM
Mopar_Man's Avatar
Well a wile back AirForce One Performance used my truck for the R&D on there new Intake horn. Well the first perduction run is done and hear it is http://www.btgmotoring.com/Merchant2...Category_Code= I took my CFM+ off for this one. Its cheaper than all the other ones out there and IMO looks way better than the rest of them.
Old Sep 18, 2008 | 07:52 PM
Mike Holmen's Avatar
The Guru
Nice looking unit. The stocker is abit restrictive, nice mod.
Old Sep 18, 2008 | 09:28 PM
kgspeed700's Avatar
nice looking horn, i put an afe on didnt make a difference just got it for the the pre tapped holes for gauges and water meth but it has to help it breather a little
Old Sep 18, 2008 | 09:43 PM
rob24vctd's Avatar
Pm me if you wanna get rid of your CFM+
Old Sep 19, 2008 | 09:21 AM
Mopar_Man's Avatar
Sorry already sold the CFM+ now that I have this one its time to do a mechanical boost gauge and water/meth
Old Sep 19, 2008 | 10:26 AM
97 D-Tec's Avatar
I have one sort of like that but it only cost me 160
Old Sep 19, 2008 | 10:58 AM
Mopar_Man's Avatar
The CoolerTubz one in your sig? I have seen that one. If you were to put these two side by side there is no comparison between the two.
Old Sep 19, 2008 | 01:30 PM
97 D-Tec's Avatar
yea i mean mine isnt as refined but it does work very well as for which ones better well ur probably the only person who knows
Old Sep 19, 2008 | 05:42 PM
HOHN's Avatar
Why the transitional mismatch? The pic shows a round outlet while the CTD inlet is square with rounded corners.
It's amazing how people think a piece like this is something special. It looks cool, but let's get real-- it's mandrel bent exhaust pipe with a welded adapter plate, some other weld-ons and a lot of plating.
It looks cool, but the amount of "engineering" in a piece like this is very low.
I'm waiting for someone to build a proper "cobrahead" style intake for our trucks.
Alas, the tooling costs of hydroforming for a piece like that can be pretty steep. Shoot, the tooling just for a sandcast is expensive, never mind a die cast or a gucci hydroform piece.
Old Sep 22, 2008 | 09:23 AM
Mopar_Man's Avatar
1st of all I hear what your saying. But it does flow much more air than the stock one and that is the whole point to these type of parts. I feel it flows as good as any of the aftermarket intake horns on the market. Other wise i would not have sold my CFM+ for this one. and 2nd there is NO plating. Its polished Stainless not plated.
Old Sep 22, 2008 | 09:38 AM
Clayten's Avatar
DTR's Toad Wrangler
I agree Hohn
Old Sep 22, 2008 | 02:12 PM
97 D-Tec's Avatar
Say what you want but it works better then the stock one and i can back it up because i have one on my truck and Ive had it for awhile with gains of better throttle response, and a lil bit of boost and thats all that matters
Old Sep 22, 2008 | 03:00 PM
Mopar_Man's Avatar
I agree with 97 D-Tech it flows much more than stock and that is all that matters. Every little bit helps
Old Sep 22, 2008 | 03:37 PM
impmouse's Avatar
wish the end was beed rolled so the pressure or boost would not blow the hose and clamp off ,if that was done would be a nice piece
Old Sep 22, 2008 | 03:40 PM
Mopar_Man's Avatar
Dont think that is going to be a problim. If that end was shorter it prob would be but there is more than enuff contact surface airea that does not happen.
