Installing a Potentiometer in place of the TPS
Old Oct 22, 2007 | 07:29 PM
Charles C. Stan's Avatar
Right on: good job
Old Oct 22, 2007 | 10:53 PM
DBF's Avatar
DBF
Originally Posted by TOMTOM
Will this POT conversion allow enough adjustment to keep the trans from shifting into o.d.? Would like to delay shift as much as poss.
TOMMY
Yes.
Just a note: Whatever value you set the pot to will result in a range of rpm where the trans will shift into OD. Mine is set where slight acceleration will shift at 35mph, but if I put my foot down it shifts at 55-60mph.
DBF
Old Oct 23, 2007 | 12:21 AM
Chrisreyn's Avatar
OK, I went out earlier today and got everythign to do this, including a soldering iron, however, after a few dozen practise attempts at using it, i cant get my solder to hold the wire onto the POT....[( never used one before ) whats the trick ?????
Edit: I bought one of the "cold-heat" soldering irons.. jsut read the reveiws and it seems I have wasted my money, everyone of the "geek" sites are panning them as too difficult to get a good joint with and such...
Radio Shack had everything I needed except the 3-4 strand sheilded cable, which I got at NAPA for $.40 per foot..
Will installing the POT affect the cruise control BTW??
Old Oct 23, 2007 | 12:38 AM
RuralCruiser007's Avatar
All you are doing by changing the TPS to a Pot is affecting the shift points. The TPS only controls the transmission. On newer trucks where they are drive by wire, it will affect your cruise. You have to remember that we are drive by cable.
HTH
Old Oct 26, 2007 | 01:46 AM
Chrisreyn's Avatar
Ok, two days now of running with the POT, installed EXACTLY as Tucker did it, and I LOVE IT!!!
With the "low" stop of the POT at about 12 O'clock, 2 o'clock is engaging at 35( for city cruising), 3 o'clock is engaging around 47( towing)...
Looks like my MPG is definitly up, tho I havent calculated it yet...
I would absolutley recommend this mod as a "must -do"
THANKS FOR THE HELP TUCKER!!!!!!!!!!!!!!
Old Oct 30, 2007 | 12:58 AM
91.5 beater's Avatar
Good directions, mine is gettin one this week!!!
Old Oct 30, 2007 | 03:12 AM
Chrisreyn's Avatar
Ok, jsut returned from a trip down to the O'zoarks and this was a great help!!
set teh shift point up to around 50 and had no trouble at all maintaining speed thru the hills down there.
I did realize i had the POT installed upside down in teh dash so to speak...
Old Nov 5, 2007 | 10:35 AM
93beater's Avatar
awesome write up, but im a little confused, you loose your passing gear and by that do u mean a downshift at full pedal, and is it a big deal? usually when i tow i turn o/d off till about 45 50 then i roll on in o/d, will this be hard to get used 2? and will it help me get better milegae?
Old Nov 9, 2007 | 12:50 PM
where do the wires go on the potentiometer
Old Dec 21, 2007 | 04:32 PM
Fred Swanson's Avatar
This mod should work on the 94-95, on the 96-9812V's, it'll possibly affect your shift points too with the electronic gov control for the trans.
Old Dec 23, 2007 | 02:18 PM
Brutalowner's Avatar
Rat-Shack part #'s for reference: Potentiometer #271-1720, ***** #274-403
D-sub connectors #276-1427 should be about $8
Old Dec 24, 2007 | 04:53 PM
wminmi's Avatar
stupid question of the day: will this work on a '89 with the 3-speed auto?
Old Dec 24, 2007 | 09:50 PM
No need, you don't have overdrive (or a TPS).
Old Dec 25, 2007 | 09:31 AM
wminmi's Avatar
thought this was only for OD.....now i feel stupid lol
Old Dec 27, 2007 | 05:13 PM
SHARPMACHINE's Avatar
So, has anyone tried it on a 96-98?????
