Installing Headlamp Relays
Old Dec 14, 2017 | 02:14 PM
  #181
1stGEN'93's Avatar
Hookup
Can someone post more pictures of how the system hooks up to the truck? How do the relays hook up to the headlight switch? I’m just kind of confused how the whole thing hooks up. Seems like a good write up, just a dummy like me who doesn’t understand much about electrical is confused without more pics on how it hooks up to the truck.
Old Dec 14, 2017 | 02:47 PM
  #182
Pictures ? Don't think I have any...
The relays are hooked up to the battery (preferably through a fuse panel that you add to the under hood area) where they draw their power. The headlamp wiring that is already in the truck is simply used as the "trigger" point, so when you unplug the driver side headlamp, you test the port to see what part of that plug does what ? Low beam, vs High beam. One feed will trigger the relay to connect power from the battery to the headlamps through a #12 wire, making the low beams work. The other feed will do the same for the high beams. This means that when you're in the truck, and you turn on your headlamps, the plug you removed from the back of the headlamp ( I used the driver side only), turns on the relay, which then sends power back to the headlamp through the new #12 wire.
Old Dec 14, 2017 | 03:11 PM
  #183
edwinsmith's Avatar
I bought a kit off Amazon to do this. Took about 20 minutes to install and was a lot cheaper than sourcing the parts separately.
Edwin
Old Dec 14, 2017 | 04:00 PM
  #184
1stGEN'93's Avatar
I guess when I get ready to do it I’ll have to read through this whole thread more carefully then. If I’m understanding correctly now the wires that go into the relays are coming from one of the stock plugs?
Old Dec 14, 2017 | 05:00 PM
  #185
mknittle's Avatar
This may help some? post 1179.
https://www.dieseltruckresource.com/...314771/page79/
Old Dec 14, 2017 | 05:50 PM
  #186
edwinsmith's Avatar
Here's the kit I bought on Amazon:
Amazon Amazon
If you do a search on Amazon for "Headlight relay kit" you can get much cheaper prices.
The kit I got just plugged into the existing headlight plug on the left side. I bolted the relays to the core support and connected the ground and the power directly to the battery through a 30 amp circuit breaker that didn't come in the kit.
I also bought some Hella Vision Plus headlights with replaceable bulbs and I put in 100/80 watt bulbs. Really makes a difference.
Edwin
Old Dec 15, 2017 | 11:08 AM
  #187
1stGEN'93's Avatar
Originally Posted by Jim Lane
Or wow these are bright.
Geez,
I cannot believe it has been this long, It was back in November of 2007 that I brought this write-up to all of my friends here.
My relays have been working flawlessly and as designed for over SEVEN years now.
https://www.dieseltruckresource.com/...relays-176263/
I had designed them to complement my Sylvania Silver Star H6054 headlamps and it did so with unparalleled brightness but I soon learned they had such a high output, by pushing the hot filament at 13.8 volts, so now they are extremely bright but they do not last very long, for me only about 8 months for the pair.
I have also installed my 160-amp Leece Neville alternator to charge my 5 onboard batteries, with my 10-gauge wiring to my headlamps the voltage at the socket is 14.0 volts and is limited to 30 amps so needless to say, they can be very bright, yet it is a controlled beam, nothing like the ricers with the blinding blue HID's in cheap composite housings.
But $60.00 every 8 months was starting to add up and I figured at some point I needed to make a decision on a different kind of light, my dream of a Zenarc HID system was crushed by the $1000.00 price tag, eventually I will get my LED's headlamps but for now Composite Housings
I wanted to try the new Silver Star Ultras so I bought a pair of Autopal composites off e-bay and I figured for the price they would probably be junk, and they are, beam pattern is crappy and a lot of flare but the ultras work great.
I got the Ultras from Auto Zone for $60.00 with a $10.00 rebate and a replacement warranty, bring them back and they give me new ones.
Attachment 51099
Here is the back side of the Autopal, with a standard H-4 lamp.
For these to fit, I had to trim out the buckets using a Greenlee gutter punch
Attachment 51100
It is very important to install and secure the weatherproof dust cover to keep out the dust and moisture from inside the housing.
Attachment 51101
Here are my relays, yes I have 4 of them, one relay for each lamp.
I switched out one of the Bosch relays for the Tyco to check an issue but it has since been changed back.
Attachment 51102
Here is where my relays reside, when you install your relays, think about how water is going to roll off the hood and onto the relays and install a shield to protect them since it doesn't rain in California no worry here
Attachment 51103
Ok, here is the wall I adjust my lights on, when you get closer, all of my marks are there, I just backup 25 feet and aim the lamps.
As you can see, there is a lot of flare above the cutoff line but I guess still not bad for housings made in India.
Attachment 51104
And then here are the high beams.
About the lights, I can sit into oncoming traffic into a city police car and they do not blink their lights at me to dim mine so I take that as their approval.
Attachment 51105
Looking into the face of the lamp.
Attachment 51106
And since I have this awesome lighting on the front of my truck, you know I am going to have awesome lights out the back also.
Attachment 51107
I just wanted to remind you how much this modification will improve your forward lighting, even if you only have regular halogen lamps this will make them much brighter and much safer to drive and take virtually all of the load off your headlight switch, going from amperes to only milliamperes.
As I had mentioned, plug and play,
You can build this on your kitchen table and then take it outside and plug it in, and then go out tonight and play.
Might try a pair of these.
003427291 Hella - H4 Headlight Conversion Kit At StylinTrucks.com
Jim
What did you do for lights on the rear? Are you implying that the reason you have 4 relays is 2 for the front lights and 2 for the back lights?
Old Dec 15, 2017 | 07:18 PM
  #188
MrFusion's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Edwin
I built the Jim Lane version because it is heavier duty than the one on Amazon and uses a more standard heavier duty relay. The one on Amazon is probably fine and it WAS a PITA for me to source all of the parts. I just wanted something I didn't have to worry about.
Old Dec 15, 2017 | 08:55 PM
  #189
edwinsmith's Avatar
I certainly understand that! Did you get high temp sockets for the bulbs? That way you can use the high output bulbs like I did without burning up the sockets.
Edwin
Old Dec 16, 2017 | 09:53 AM
  #190
kensmachine's Avatar
Painless wiring also makes a kit.
I have one of the China made kits I got off Ebay It works it's cheap but it's not a quality part.
Like most China Made **** it's never quite right the part may fit it may work electric clips may sort of fit.
case in point I put the the China made kit in my truck it worked for a few months them the lights started to flashed when I went over a bump in the road traced it down to the fuse that was in the system it was a 20 amp fuse but the blades were way too thin and not wide enough put a new fuse in it and it works fine now.
next 2000 VW golf TDI I was given needs some work the center armrest was broken. A new OE one on Ebay was $150.
I bought the $18 China made one it's not as nice as OE one it did fit sort of. BUT there is always A BIG BUT it wouldn't latch had to go after the plastic casting flashing with a razor blade same with the rubber bumpers they were too tall it now latches.
I have friends that have auto repair shops they complain all the time about about the parts we get these days the parts may or not fit well they install the part it works then fails the parts houses replace the part but don't cover the labor. Ken
Old Dec 16, 2017 | 10:10 AM
  #191
Me too. I used the ceramic plug ends for the heat dissipation Edwin mentioned.
Old Dec 16, 2017 | 10:56 AM
  #192
MrFusion's Avatar
Edwin
Yes I used ceramic bulb sockets, the correct wire gauges (i found the prefab Chinese harness to be a bit light on the wire gauges), relay sockets with legit 12 gauge power wires and HVAC grade connectors. All connections soldered and shrink wrapped with the sealant filled shrink tube.
The hardest part to find was the 12 gauge wired relay socket. Most were barely 16 gauge.
Old Dec 16, 2017 | 12:46 PM
  #193
Where did you ultimately find them?
Old Dec 16, 2017 | 03:59 PM
  #194
mknittle's Avatar
These are the ones I used.
https://www.ebay.com/itm/Ceramic-Fem...BXWutl&vxp=mtr
and these plugs for the relays.
https://theelectricaldepot.com/relay...28b78002986a6b
and these for the tap into the stock headlight plug on the truck
https://www.ebay.com/itm/Pair-NEW-H4...BSEn8~&vxp=mtr
Old Dec 16, 2017 | 04:18 PM
  #195
edwinsmith's Avatar
Using the power formula I calculate that 100 watt bulbs would draw just under 8 amps so 12 gauge wire is complete overkill. In fact my 30 amp circuit breaker is too. The only reason I used it is because both high and low beams will be on at the same time when switching. On the harness I bought the high and low circuits are separate so the wiring is adequate.
