Installing Headlamp Relays
Old 12-16-2017, 04:37 PM
  #196
Jim Lane's Avatar
I get all of my relay sockets and relays from a Heavy Truck Parts near me,
They have a true 12-gauge wire on terminal #30, #87 & #87a #85 & #86 are 16-gauge,
I think he said they are from Cole Hearse.
I just found my HD headlamp sockets were starting to melt as well.
I think the reason being the blades on my H4 Silver Star Ultras are thinner than the ones on regular H6054 glass lamps, causing a weak connection which will eventually overheat.
LED headlamps are on the list for my truck.
Might want to keep an eye on this.
Jim
mknittle (03-09-2018)
Old 03-07-2018, 10:32 PM
  #197
1stGEN'93's Avatar
What did it run you guys to build this set up? Just wondering as LMC now has a kit for our trucks that looks pretty decent for $30.
Old 03-08-2018, 11:31 AM
  #198
cougar's Avatar
I bought the Putco setup (several actually) off amazoid for about that price. After more than 5 years they still work just fine.
Old 03-08-2018, 12:02 PM
  #199
1stGEN'93's Avatar
I guess $30 plus shipping and tax will be removed from my bank account this afternoon then
Old 03-09-2018, 11:42 AM
  #200
Shelby/Dakota's Avatar
Dang, at that price, its worth it just to avoid the hassle of dealing with building he harness yourself.
Link please?
Old 03-09-2018, 12:04 PM
  #201
1stGEN'93's Avatar
Link please?
Heavy-Duty Headlight Harness | 1972-93 Dodge Truck 1974-93 Dodge Ramcharger | LMC Truck
Old 03-09-2018, 04:01 PM
  #202
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
That's almost exactly the same set as I got. Mine has white plastic on the headlight plugs though. You should add a 30 amp breaker in the supply line and connect it to the battery.
Edwin
Old 03-09-2018, 04:07 PM
  #203
1stGEN'93's Avatar
Edwin
Can you explain to me what a breaker is? I have pretty much zero knowledge of electrical.
Old 03-09-2018, 04:34 PM
  #204
edwinsmith's Avatar
A circuit breaker watches the amount of current flowing through it and like a fuse it "breaks" the circuit to prevent damage to the wiring if an overload occurs.
Here's the one I used.
https://www.oreillyauto.com/detail/m...350-pickup-rwd
Edwin
mknittle (03-11-2018)
Old 11-18-2019, 01:57 PM
  #205
dparker's Avatar
Has anyone run this setup with LEDs?? I built this harness about 10 years ago following Jim's instructions with Highs and Lows on at the same time and it has worked flawlessly. Looking to upgrade the lights and interested in LEDs.
On a side note, looking for suggestions on which brands lights to good and what I should stay away from? I'm a firm believer in "you get what you pay for".
Thank you
Dustin
Old 11-18-2019, 04:05 PM
  #206
Received 2,378 Likes on 1,572 Posts
I installed the Truck Lite headlights on my '91.0 and I really like them. Not cheap, but I would say you get what you pay for with them.
One downside which likely will not effect you much in AZ is they use so little electricity that they make no real heat, which would normally keep the headlights from icing over in cold wether and snow.
Since I run them on my summer only ride it makes no difference to me on my '91.0
dparker (11-18-2019)
Old 11-19-2019, 10:56 PM
  #207
j_martin's Avatar
Thank you
Dustin
LED's should run good with the relays. Actually, with LED's the relays wouldn't make much difference.
Jim Lane
02-13-2019 07:19 PM
IHCsawyer
12-27-2016 04:36 PM
Jim Lane
11-25-2015 04:22 PM
txfiremedic
59
02-10-2012 03:13 PM
NE frmhnd
04-21-2011 10:24 PM
Quick Reply: Installing Headlamp Relays
