Installed HE351CW Turbo = No Boost
Need help guys! I put on the '04.5-07 HE351CW turbo on the old Power Wagon and now I get only about 3-4 pounds of boost. The impeller turns freely, have a stiff spring holding the waste gate closed, all the intake plumbing is in place.
I'm stumped as to why it won't spool up and make some boost? Please advise.
Good day, Mike Mc. From my experience with the HE351CW, I don't recognize that nipple fitting off the bottom of the solenoid port on the intake housing. Maybe that is a boost leak?
Good luck with your T/S. Nice 351 by the way. I'm looking for one myself.
I got the nipple on the intake plugged. There's a sheet metal screw in it with a dap of red silicone. Maybe the spring is allowing the waist gate to open up.
Try tying the waste gate shut
I'm an idiot My dumb *** had the waist gate all the way open. Unhooked the spring, flipped it over, hooked the spring back up. Now it makes about 28 pounds which is about 6 pounds more boost than before. Happy Happy
mk. ya buddy sure glad it was a simple dumb mistake...... boy I make a lot of them too.
Went out driving around tonight. Not sure how much more power it has but its has a CRAZY amount of whistle and I love it Every little fluctuation of the throttle I can hear in the turbo. Maybe the big air cleaner allows more whistle to escape?
VE pumped 12V with an HE351CW with big intercooler is a very nice setup, my favorite.
I'm hauling heavy with it right now. Truck 9k. Trailer 12k. Pull trailer 3k. When I'm pulling hard it's getting about 29lbs of boost. If I put on a stiffer spring what's the max boost for a '93 5.9?
That is one cool picture of your classic tow "mule"!
What is your timing set at? If close to stock, I would be comfortable at 40 if you torque the head bolts.
