Inside our doors.
Old Oct 1, 2008 | 08:40 PM
Jim Lane's Avatar
Post Inside our doors.
Part-1
Lets see what is inside our door.
My truck is a 1991 D-350 LE edition so it will have all of the fancy extras.
Here you can see the wiring harness for the power windows, door locks and power mirror.
The extra holes in the upper left were cut to easily access the window lift motor. This is covered in the Sticky under Window Motor Repair.
This is a view of the Power Lock actuator.
Notice the square patch on the left side of the door; this is how the factory deadens the sheet metal.
This is where you would want to install some deadening medium like DynaMat or some form of Tar board
Inside of the lower hinge and the door speaker and connection.
Speaker and the weather shield.
Harness as it enters the door; the harness going up is to the Power Mirror.
Bottom of the lift motor and it’s connection.
Here is how I quieted the interior of the door with carpet padding, also make sure that all of the spring clips are installed on the door panel.
This is how I keep it in place, Mylar HVAC tape.
Passengers side control panel.
I also inserted some foam insulation behind the switches to contact the door sheet metal to keep everything nice and tight.
Old Oct 1, 2008 | 08:41 PM
Jim Lane's Avatar
Post
Part-2
This is what the door latch assembly looks like.
It was really grungy looking so I cleaned it off using a good Carbonated Carburetor Cleaner and used compressed air to blow it dry. I then re-greased all of the moving parts with good quality grease.
Just another view.
And another.
Afterwards I reinstalled it into the door and reconnected all of the linkages to the lock actuator and the lock button.
I hope this trip inside our door will be of some help to someone.
Jim
Dave,
Maybe we can save this for future reference.
Here are some drawings and Part Numbers:
Old Oct 1, 2008 | 08:53 PM
DNRCustoms's Avatar
let me tell you that you are the man, I really needed a pic of how the wiring ran, I forgot if it ran along the outside of the door and swept in to the plugs.. But this little write up you did sure helped... I just changed all the guts in both doors with some modifications... Because my new doors were way different than the old ones.. But nice write up and I'm sure it should go straight to the stick for a future referance..
Old Oct 2, 2008 | 03:42 PM
C Pierce's Avatar
Jim I also really appreciate all of your write ups and the great pics along with them. I have'nt been able to do much to my truck lately but when I look at youre posts and write ups I get totally Inspired so thanks and keep it up!!!
Old Oct 2, 2008 | 04:52 PM
Very cool pics, Jim.
Old Oct 5, 2008 | 02:48 PM
whereswaldo250's Avatar
Great write up, very helpful
Old Oct 5, 2008 | 08:11 PM
loch's Avatar
nice little note, now i just have to ask, how the heck does yours stay clean ?
Old Oct 5, 2008 | 08:12 PM
roxxx's Avatar
yea same here. I was thinkin that was like 1 ST Gen diesel **** pictures
I am scared to look in my doors
Old Oct 6, 2008 | 02:31 AM
Jim Lane's Avatar
How does it stay so clean?
Thanks for the complements,
It stays so clean first because it is a California truck and it has never seen a salted road or mud up to the headlights and every time I wash the truck the engine also gets washed and dried with compressed air it get it also gets washed under the hood and wheel wells.
When I had the door panels off I wiped down the insides of the doors but I did miss a little on the speaker shield I see, Oops.
When I had my dash apart to repair the instrument cluster that gave me the opportunity to really do a good cleaning under the dash.
Whenever I work on anything I will always clean it out first so I don't get dirty, every time I get out of my truck I have a brush that I keep next to the door that I use to sweep out the floor several times a day and always at the end of the night and yes I have been told I have OCD.
I am glad you guys liked it.
Jim
Old Oct 6, 2008 | 01:36 PM
loch's Avatar
uhm ok thays just not right, throw some good old red dirt on it, it will run better.
Old Oct 6, 2008 | 05:51 PM
archer39's Avatar
did the carpet padding help with noise reduction?
Old Oct 7, 2008 | 03:42 AM
Jim Lane's Avatar
Post
Yes it did help quite a bit, before when I closed the door there would always be a rattle from all of the parts hitting each other but now there is just a solid clunk.
It also cut down on the noise from the outside by allot, if you look you’ll see the doors are a big acoustic chamber.
The padding is I think was 7/8" so I cut out the relief so it would sit flat on the door. I also made sure that all of the spring clips were there and installed into the holes in the door properly for a nice tight fit.
I am looking for a deadener to install onto the inside if the door shell to cut down on all of the sound, I have to look at the duct liner used in HVAC when I go the supply house, I could install it in a few sections through the access holes.
My goal is to be able to slap the outside of the door shell and have it not resonate at all, just a clunk.
Jim
Old Feb 10, 2020 | 07:13 AM
Jaybug's Avatar
Jim, unfortunately photobucket appears to have intentionally blurred all of the wonderful photos in this sticky.
The new owners of photobucket now want to be paid so they have watermarked all the images. https://prnt.sc/p71hi1
6.7L MegaCab
Nov 5, 2017 03:43 PM
ET RAM
Jul 30, 2009 09:55 PM
cbrahs
69
Aug 8, 2007 10:40 AM
4RnrRick
Dec 27, 2006 06:08 PM
kstrongsyj
Oct 25, 2003 08:07 AM
