Injectors!!!!
Injectors!!!!
ok guys i know yall haul some loads so here is wher yalls advice comes in, ive got a 90 non i/c truck, i haul between 15 an 23,000lbs of hay an other things on the farm an road,ive got gauges an a 4in exhaust into 5in bedpipe an stacks,asa intake anhead work i need to know whats the best injector to get more power for the loads i pull it does fine pullin now but i want more power
NON intercooled injectors are huge. the only upgrade from them would be like POD's or EDM's. POD's run real dirty and run hot unless you have alot of turbo. 20,000k is alot to tow with pod injectors. however, they are very CHEAP for the power you get,but there may be bad results. I think EDM's is your best bet. but there EXPENSIVE like $700-1300,however, they run kinda cool and will give you alot of safe power with a tuned pump. The injector experts will chime in... but my 2 cents is to keep your stockers. there pretty big and will supply alot of fuel for your needs. You should fill out your signature.
. Brandon
. Brandon
My advice is a set of stock IC'd injectors EDM'd to .014" with a 62mm turbo of your choice and some W/M as well as an intercooler and some 3" tubing. That's alot of fuel to burn and you will need some more timing too. You could make a nice towable 350HP truck. But you will need the coolers. That's just my opinion though.
darrenG
Jun 21, 2005 10:24 PM
