Injector question?
Old Aug 5, 2008 | 08:03 AM
super-duty's Avatar
Injector question?
What is the difference between 1st and 2nd gen injectors? I know there is a size difference but where on the injector is diffrent. Can a 2nd gen injector be used in a 1st gen (what mods needed)? Are the heads interchangeable??
Just trying to learn more things so thanks for the help.
Old Aug 5, 2008 | 08:13 AM
JD730's Avatar
The largest 2nd gen injector is smaller than the smallest 1st gen injector nozzle.
The body is also different, 1st gens use a 12mm thread and the 2nd gen uses a 14mm thread, pop pressures are also different, much higher on a 2nd gen.
The cylinder heads will interchange.
Old Aug 5, 2008 | 08:14 AM
apwatson50's Avatar
The pop pressure is different and so is the angle on the injector line inlet seal. The tips are interchangeable though.
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
