Injector Problems
Old Jan 28, 2007 | 03:41 PM
dodgec68's Avatar
Injector Problems
My truck is running really rough now and will not smooth out even when warm. already put a fuel filter on and it did nothing. what normaly happens when an injector goes bad or gets plugged?
and will a 1989 ctd set of injectors work on a 1992 ctd?
thanks fr the help
jesse
Old Jan 28, 2007 | 03:46 PM
Check for air in the fuel by plumbing in a short length of clear hose before the lift pump. Does not have to be diesel rated, it's just for testing purposes.
Also check fuel pressure. You should have a minimum of 3 psi at idle.
Old Jan 28, 2007 | 04:01 PM
G1625S's Avatar
no, sorry
Old Jan 28, 2007 | 04:11 PM
dodgec68's Avatar
what about clogged injectors?
Old Jan 28, 2007 | 06:06 PM
2stroke's Avatar
i think they are trying to tell u to go over some other things before u condem the injectors.i would check for air 1st, then loosen injector lines 1 at a time and see if 1 makes more of a difference than the others.
Old Jan 28, 2007 | 06:48 PM
dodgec68's Avatar
Yeah, I am going to check on the air in the lines when I get home. But I figured that I would ask about the injectors also. I tried cracking the injector line when I changed the fuel filter and they all affected the motor the same way each time.
thanks
jesse
Old Jan 29, 2007 | 05:59 PM
Then it's probably not the injectors.
Old Jan 30, 2007 | 12:07 PM
dpuckett's Avatar
*IN MY EXPERIENCE* the line crack is a very poor test for injector condition. I've had injectors that affected the engine the same way, turn out to be evenly bad- 1000psi low and clogged. You can remove them and get them checked for free most of the time, you're out a little time and a few washers. But, I'd reserve it for a when-all-else-is-exhausted option. No need to go pulling injectors if you are getting air in the system somewhere.
Daniel
Old Jan 30, 2007 | 01:27 PM
dodgec68's Avatar
Thanks. yeah I am going to try and check for air in the lines tonight, and i will post again on what I find.
Jesse
Old Jan 30, 2007 | 06:34 PM
pred's Avatar
?head gasket? Did it start doing it all of a sudden?
or slowly as the right foot hours added up?
Mine wasent an injector with 316K miles, It was the head gasket.
Old Jan 30, 2007 | 08:58 PM
dodgec68's Avatar
do you mean cut he fuel line before the lift pump?
Old Jan 30, 2007 | 09:47 PM
dodgec68's Avatar
don't think it is a head gasket, no water in oil, and it has slowly goten worse.
Old Jan 31, 2007 | 10:48 AM
dpuckett's Avatar
Lack of oil and water mixing isnt necessarily an indication it ISNT the head gasket; just means it didnt blow between an oil and water passage. Lots of times they will blow externally, or between cylinders, causing all kinds of weird problems. I would however, check the injectors with your years and miles. Cheaper and easier than a head gasket.
DP
Old Jan 31, 2007 | 03:24 PM
pred's Avatar
When my HG finally warrented replacement, It was passing cylinder to cylinder in two spots, NOT into the oil or coolant.
Old Jan 31, 2007 | 04:39 PM
No, don't do that. The '92 and '93 trucks have plastic fuel lines that almost never give trouble, don't mess them up. There is a quick disconnect at the lift pump. Disconnect it, remove the fitting from the pump, thread in a hose barb, and adapt the quick disconnect to another hose barb. Put the clear hose between the barbs.
