Injector Line Sizes?
No idea. I'm running a set of non-intercooled lines with a non-intercooled pump on mine right now. Don't know if theres an advantage or not.
I also ran a 14mm H/R with the intercooled lines.
Old topic but I have been thinking about this lately.
So intercooled lines are 1.85 mm = .073".
Non intercooled are 2.00 mm = .079" or 17% larger than intercooled.
Custom built 2.14 mm = .084" are 33% larger than intercooled and 13% larger than non intercooled.
Custom built 2.37 mm = .093" are 62% larger than intercooled and 39% larger than intercooled.
Is the original injector line size info correct?
I found one website that lists 1st gen lines as .067" = 1.70 mm.
What does it take to put non intercooled lines on a intercooled pump?
Is there a gain to be realized?
I had a similar question regarding non-IC delivery valves on an IC pump. For that matter what about non-IC DV's and lines on an IC pump. Or should I go to oversize lines and non-IC DV's to feed my 6x18's?
